Go to Post Our robotics lab has been closed for two days, TWO DAYS! :ahh: - Kevin Selavko [more]
Unread 18-02-2013, 10:04
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Re: Programming RGB lighting
If the strip you are using is 4 wires RGB and Power/Ground, you cannot power it directly off the DSC you will need transistors because the DSC cannot handle that much current.
2015-2016 CSA
Software Engineering Student @ Johnson & Wales University
Team 228, Gus Robotics Inc.
Facebook
FLL Mentor for 1107, Edison Eagles!
2015- CT State Champions
2012- WPI Finalist(Thanks 1884 and 549), Spirt, Best Website
2011- WPI Chairman's award winners!
2010- WPI Champions! (thanks 230 & 20), WPI Engineering Inspiration, CT Best Website, CT VEX Champions (VRC228, VRC228b) (21-1-0)
2009- QCC VEX Champions (VRC228) (11-0-0), Innovate Award (VRC228)
Unread 18-02-2013, 11:16
CooneyTech CooneyTech is offline
FRC #0269
CooneyTech is an unknown quantity at this point
I talked to some mentors and we are going to power it off a DIO with some solid state relays.
Unread 18-02-2013, 13:32
FRC #0228 (Gus)
Solid state relays will not allow you to mix colors you would need transistors
SSR's only work on and off
2015-2016 CSA
Facebook
Unread 18-02-2013, 15:44
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
What do you think a solid-state relay is made out of? (power FETs, SCR's, Triacs, etc are all types of transistor.)
The LEDs intensity is controlled by PWM (Pulse Width Modulation) which IS an ON/OFF function.
They are on the right track here.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
