Go to Post Its not the type of material you use, but how you use it... - jrocket567 [more]
Unread 18-02-2013, 17:13
C.I.S. C.I.S. is offline
FRC #4607 (Coalition of Independant Students (C.I.S.))
C.I.S. is an unknown quantity at this point
Re: NI 9472 Module No Lights Please Help
Here's our code in attachments
Photo.JPG --- Begin VI
Photo(2).JPG --- Teleop VI
Photo(3).jpg --- Finish VI
We followed a LabVIEW picture for coding a Double Solenoid. We believe now that our problem may be that we coded for a Double Solenoid when we actually have a Single Solenoid but we didnt know if that would make a difference on whether or not the crio lights would light up.
ID:	14097  Click image for larger version
ID:	14098  Click image for larger version
Unread 18-02-2013, 17:39
You'll need to code for a single solenoid for the code to work properly.
Something like this:
Check your solenoid too for 12v vs 24v and make sure the voltage matches the power you've wired into your Solenoid Breakout.
Unread 18-02-2013, 17:48
Yes! Thank you. We coded for the single solenoid and the lights lit up via the joystick buttons.
