Go to Post Remember, GP doesnt just need to apply to FIRST; if we all apply in our lives as a whole, the world will be a better place. - Dillon Compton [more]
Unread 18-02-2013, 17:08
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Over weight robot
Did you release your compressed air before weighing? That can also make a noticeable difference.
Unread 18-02-2013, 17:10
Shane 2429 Shane 2429 is offline
FRC #2429
Shane 2429 is infamous around these partsShane 2429 is infamous around these parts
drill anything not structural and if that doesn't help any drill more holes between those holes also look for anything not entirely necessarily and see if can removed
so in short drill holes drill holes and drill more holes
Unread 18-02-2013, 17:15
Originally Posted by Priyesh69 View Post
Our arms are pretty heavy 7lbs each. In this short time we cant get smaller piston.
Depending on when your regional is, you have time to order lighter ones now that you can drop in during practice day of your event. You also have the withholding allowance....
Unread 18-02-2013, 17:22
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
This is a bit of out an out there idea but you can replace the AM kit frame corner brackets with 1/8 plate gussets. EX: http://www.chiefdelphi.com/media/photos/38516 And use rivets instead of bolts.
Edit: http://www.chiefdelphi.com/media/photos/38390 cad files are in this.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 18-02-2013, 17:34
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
I know you guys are short on weight, but are your accumulators plastic?
If they are, check this out...
It may be a good idea to keep the plastic accumulators, but please see the risk involved with it.
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 18-02-2013, 17:36
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Calculate the mass of the holes before you drill any. Use the volume of a cylindrical hole times the density of the material you're thinking of drilling. This should only take a few minutes to estimate.
Additionally, some cost-benefit analysis of your mechanisms and drilled holes is in order. Are you better of by sacrificing a mechanism and just getting the robot finished, or by taking the next day or so to drill holes in things?
And this goes without saying: everyone participating in your decision must understand the weight limits in the rules.
Unread 18-02-2013, 18:00
Mk.32's Avatar
AKA: Mark
Oh also, make sure your scale isn't to blame. Get a student that knows her/his weight to stand on it to check or object. You never know!
Unread 18-02-2013, 18:06
Additionally, make sure you are using a scale that goes up in small increments.
Unread 18-02-2013, 21:39
DonRotolo's Avatar
Back to humble
FRC #0832
We are taking out the manifold and the compressor
Queston: will we have enough air
Enough air for what? If you have 2 plastic tanks and one cylinder like in the photo, probably yes, for one time. If you have 2 cylinders and others, then maybe not. TRY IT AND SEE.
Unread 18-02-2013, 21:44
giantmidget31's Avatar
giantmidget31 giantmidget31 is offline
Eat robots, build waffles.
FRC #0555 (Montclair Robotics)
Team Role: Electrical
giantmidget31 is an unknown quantity at this point
We were very overweight, so we took off our shooter! It wasn't working that well, and we were easily able to turn our disc lifter into a level 1 dumper, which may even score more points than the level 3 shooter, and we still have our climber.
Unread 19-02-2013, 08:01
Swampdog Swampdog is offline
FRC #3381
Swampdog has a spectacular aura aboutSwampdog has a spectacular aura aboutSwampdog has a spectacular aura about
Holes Help. We lost 3 lbs last night. Do you have Aluminum gears in your gear boxes? That can be .4-.8 lbs depending on gear boxes.Do you have the small compressor? Do you need to motors on your shooter? How many drive sims? If 4 do you really need 4? Are you sure about your scale? Are you picking up off the floor? Do you have to? Seems like we have a fat robot every year usually don't name him until he is under. 119.9 is all it takes. Good luck.
Unread 19-02-2013, 09:47
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
Try replacing a compressor with a mini compressor, use a smaller c-Rio (we normally use the 4-block one), attach electronics to polycarbonate and Velcro them on.
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 19-02-2013, 10:09
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Originally Posted by Gregor View Post
...You can easily shed 10 lbs with just drilling holes, don't do anything drastic.
I disagree; 10 pounds worth of holes is very drastic. We've never been able to lose more than 2 lbs just by swiss-cheesing. Since some of the materials in the pictures look like they are overly heavy, maybe the holes could add up to 4 or 5 pounds.
I would look for structural parts that don't need to be so heavy-duty. Such as C-channel or 80-20 that could be replaced with angle bar, or solid 1/4" plastic or plywood that could be thinner or corrugated.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 19-02-2013, 11:07
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
Remake your shooter with lighter materials. Last year we were 20 pounds over we drilled 1023 holes and only lost 8 pounds. The bulk of our weight loss came from switching to lighter ,materials. I recommend you do the same
Unread 19-02-2013, 11:19
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
10 pounds is a lot to lose, but you can do it. Remember that you don't need to lose it all at once, small cuts add up!
First, think of how much you actually need to run your pneumatics, we have used precharged in the past and as long as you don't have a leak it works well. I would recommend taking off the compressor before removing airtanks, it is heavier and less necessary. If you are using a full sized compressor, you could start by switching to the mini one, that will save you about 2 pounds. If you have the mini one and you take it off that will be about the same.
Swiss cheese is good. Find places that you can drill holes or enlarge ones that are not critical or in use. This won't do a ton, but you could probably get 3-4 pounds out of it if you really stretch it. I would say that 3 is a reasonable goal.
Look at all of your bolts. Find which ones are extraneous and take them out. Like the post above said, you probably don't need 3 1/4-20's to hold up the 1/2 pound airtank. 2 would probably be sufficient, even 1. Heck, you could probably get by with zipties for it. That's what we are using. Find all the bolts that extend far past the nuts holding them on. switch them to the smallest possible size that you can use while still going through the nut. This could add up to about 2 pounds depending on how much you guys take out.
Find material that you don't need and remove it. This is basically just drilling holes but bigger. if you have a full plate that a frisbee will slide on, you really only need the ends, take out the middle. When possible, try using 1/16" metal instead of 1/8". It's tough to tell from the picture but this might be able to get another 2 pounds for you guys.
You probably won't want to do this, but you could also find electrical wires that are too long and shorten them to just what you need. This will cut down a pound or two and eliminate any rat's nest you might have.
As a last resort, fill your air tanks with helium before weigh in
Good luck!!!
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
