Go to Post Though, of course, if the old one you like is shot, then you can just beat your new one with a hammer until it works the way you want. - Kevin Sevcik [more]
Unread 18-02-2013, 17:12
Mr.Trips Mr.Trips is offline
FRC #3179
Mr.Trips is an unknown quantity at this point
Programing Absolute Encoders on Labview
Hello,
My team and I are trying to use an absolute encoder this year on one of the motors, to take out some of the guess work while shooting the Frisbee at the target. We have tried using the code example but still no results. Also, the Absolute encoder is the only sensor we have besides the Ultra sound. So using a different sensor is not an option. Any help will be gladly accepted, and greatly appreciated.
Sincerely,
3179
Unread 18-02-2013, 17:37
Re: Programing Absolute Encoders on Labview
What part number is this Absolute Encoder? What code example are you trying to use?
Unread 18-02-2013, 17:52
FRC #3179
I was trying Encoder.lvproj and the part number is
E3P-360-250-D-H-D-B.
Unread 18-02-2013, 17:56
E3P is an incremental encoder, no?
Unread 18-02-2013, 18:01
FRC #3179
It might be an incremental encoder but when we where looking up the encoders when we came across its number it said it was an absolute encoder.
Unread 18-02-2013, 19:09
FRC #3179
Oops on my part, It is a E4P-360-250-D-H-D-B.
Unread 18-02-2013, 21:00
What document said it was an absolute encoder?
That's an incremental encoder too. What are you trying to measure with this encoder?
