Go to Post 4 is kind of like 5 - Jaine Perotti [more]
Unread 18-02-2013, 18:17
treeturtle1 treeturtle1 is offline
FRC #1780
treeturtle1 is an unknown quantity at this point
Only Victors Won't Enable, Jags Work Fine
Greetings Friends,
Code is loaded and works within normal parameters. The jaguars work perfectly. But, the coded victors are completely not responsive. Even when moving the cables with signal and putting them in the victors, even with signal, they continue to blink yellow in their waiting stage. We can't recreate an enabled victor no matter how hard we try. If anyone has any wisdom to share, we would be grateful.
Thank you,
1780
Unread 18-02-2013, 18:26
Re: Only Victors Won't Enable, Jags Work Fine
Possibly the PWM cable plug into the victor is not engaging correctly.
That can be a challenging connection to make.
You can test the connection by taking the PWM end from the Digital Sidecar side and testing the ground and signal pins for continuity with a multimeter.
