Go to Post Could you post your code? It is hard to debug that which you cannot see... - Dusk Star [more]
Unread 18-02-2013, 20:11
jake517 jake517 is offline
FRC #4294
jake517 is an unknown quantity at this point
Position of Eye Bolt
Hello everyone,
Does anyone know where exactly the eye bolt needs to go? Or can it go anywhere (on the frame)?
~4294
Unread 18-02-2013, 20:18
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: Position of Eye Bolt
Make sure it's toward the center of gravity.
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 18-02-2013, 20:25
FRC #4294
thanks!
Unread 18-02-2013, 20:27
EricH EricH is online now
Either an eyebolt or an open spot to wrap rope around needs to be near the balance point (which is one method for finding CG), placed in such a way that it is easily accessible after the robot has climbed. See R10.
Unread 18-02-2013, 20:58
Oldbikerider's Avatar
Oldbikerider Oldbikerider is offline
AKA: Graham
FRC #3132 (Thunder Down Under)
Oldbikerider will become famous soon enough
And above it!
Graham
FIRST® TEAM 3132
Thunder Down Under
Sydney, Australia
Unread 19-02-2013, 01:30
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Originally Posted by Oldbikerider View Post
And above it!
It would be very inconvenient for the belaying points to be under the robot
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 19-02-2013, 09:32
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
I agree that the eyebolts should be above the center of gravity, which leads to the question of orientation. We're concerned about how inspectors will interpret this.
R10
Teams must supply at least two (2) attachment points for the belaying device (see Section 2.2.5) to mount to their ROBOTS. Attachment points must be:
A. easily accessible after the ROBOT has CLIMBED the PYRAMID,
B. on opposite sides of the ROBOT,
C. located near the ROBOT’S balance point, and
D. made from exposed structural members that will allow a rope to be wrapped around it or two eyelets (McMaster PN3014T45 or similar) mounted to the frame. Opening of the eyelets must be at least ¾ in. in diameter.
(emphasis mine)
Our robot climbs the outside of the pyramid corner on its belly. We put the eyebolts near the front corners of the chassis, so that if the robot were to slip and be supported by the belay ropes, it would pretty much stay safely in place.
One interpretation of "near the balance point" might lead us to put the bolts on the sides around the geometric center of the robot. In that case, if the robot were to slip, it would suddenly try to level itself. It would swing down, past level, and oscillate until something dampens the oscillation. That something might be a body part near that height, such as a head.
So, I think we're following a safer interpretation of the rule. Do you think inspectors will see it that way?
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 19-02-2013, 12:41
Are you intending for your drive team to pull the robot from the pyramid and lower it to the floor in its "tilted" orientation before removing the belay ropes? I would expect the inspectors to assume the robot will be removed and set on the floor by two people holding it in an approximately horizontal orientation.
Unread 19-02-2013, 13:08
AKA: Gerry
The robot latches onto the top rungs, using hooks near the front of the robot. So, it must be lifted 1-2" in its tilted orientation, and pulled away from the pyramid that way. We have found that it's easiest to keep it tilted that way as it is lowered, usually setting the rear bumper on the floor first, then setting the front down. This is the least strain on the lifters' backs (makes it easy to bend knees instead of waist & back), safest for people and robot.
Cal
Fairport, NY, USA
Unread 19-02-2013, 14:37
Alyssa3044 Alyssa3044 is offline
FRC #3044
Alyssa3044 is an unknown quantity at this point
You don't need to use an eye bolt if you are short on weight. What my team did (Team 3044) is we used Dyneema rope that was tied around one of our cross supports on our frame. It might be questioned by the judges, but there is no rule against using it in the manual, so it should be fine. It specified that it can hold 1600 pounds (so we can hold numerous robots).
Unread 19-02-2013, 15:03
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Judges wear blue polo shirts
Referees wear black and white stripes
Inspectors wear yellow hats.
I guarantee the judges will not be asking about your belay connection points, but the inspectors will.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 19-02-2013, 15:07
AKA: Gerry
I would expect inspectors to not accept rope for the belay points, no matter how strong it is. R10-D says that the attachment points must be made from exposed structural members that will allow a rope to be wrapped around it. IMO, rope is not a structural member. You might want to submit that to the Q&A.
I'm still concerned about the position of our eye bolts, per my post above. I may need to submit a Q&A for that.
Cal
Fairport, NY, USA
Unread 19-02-2013, 15:12
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
(emphasis mine)
I won't be inspecting at your regional, but I think all the inspectors are on the same page - the belay points are there for safety, and should be placed on the robot in a way that makes the robot safe to lower.
That said, you may be questioned as inspectors will be looking for them to be near the center of gravity, and will be inspecting it while it's sitting on the floor. If you explain how its safer and demonstrate the robot removal process for them (at the practice field?), I would personally be surprised if you were forced to change the belay points to some place that makes the robot less stable (and thus less safe) while lowering it. Of course, this is all based on your description, without having seen the robot, how it climbs, or how you remove it from the pyramid. Actually seeing the process is what would form my decision.
2016: Lake Superior WFFA
Unread 19-02-2013, 15:31
AKA: Gerry
Thanks, Jon. That's really helpful, and encouraging.
Any comment on using rope as an attachment point, as someone else posted above?
Cal
Fairport, NY, USA
Unread 19-02-2013, 15:43
Being an Eagle Scout and having done some rock climbing and rappelling, I can say that rope is only as strong as the knot that holds it together. A rope rated to 1600 lbs instantly gets a rating of 0 lbs if the knot pulls out.
That said, I would refer to R10, part D:
R10
A easily accessible after the ROBOT has CLIMBED the PYRAMID,
B on opposite sides of the ROBOT,
C located near the ROBOT’S balance point, and
D made from exposed structural members that will allow a rope to be wrapped around it or two eyelets (McMaster PN3014T45 or similar) mounted to the frame. Opening of the eyelets must be at least ¾ in. in diameter.
I wouldn't consider rope to be structural or similar to the referenced McMaster eyelet.
