Re: Solenoid problems
Do the lights on the solenoid breakout board (on the cRio) change along with the ones of the valves?
yes, they do change at the same time the valves do.
1. they are 24v
2. they are wired 24v 3. yes it is bright green 4. it is two pin ports 5. and yes they are red out side and black inside |
the solenoid break out is actually 12vs... ops found the problem but how do we fix that?
Someone else just asked that earlier today--use the open slots in the 24V port the cRIO connects to. I believe they're C and NC, can't quite remember which wire goes to which.
#7
The PDB datasheet suggests the terminals go +-+-. Best bet is to check with a voltmeter, though.
#8
Thank you for all your help!
Now it is time to put the robot in the box! |
#9
What do you mean?
We have two whole hours left. Enough time for a redesign... ![]() |
