Go to Post When fun is outlawed, only outlaws will have fun. - Gadget470 [more]
Unread 18-02-2013, 21:29
Negative 9 Negative 9 is offline
FRC #0611
Negative 9 is an unknown quantity at this point
How do you program limit switches?
Right now I have a limit switch plugged into one of the ports on the Digital IO. Now what methods/classes do use to tell whether the limit switch is pressed or not. There doesn't seem to be a "limit switch" and I'm not sure what to use.
Anyone else know?
Unread 18-02-2013, 21:36
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Re: How do you program limit switches?
Im working on the same thing for my team for tomorrow. What are you trying to control with the switch?
Unread 18-02-2013, 21:38
shank948 shank948 is offline
VP of Programming - 948
AKA: Stephen Shank
FRC #0948 (NRG (Newport Robotics Group))
shank948 is an unknown quantity at this point
Use a DigitalInput. It should be declared as a static variable, like this:
public static DigitalInput limitSwitch;
Initialize it like this:
limitSwitch = new DigitalInput(slot,channel);
To use the limit switch, call the get() method on it, which, assuming you have it wired correctly, will return true if the switch is closed and false if it is open.
Any more questions?
If it's green and slimy, it's Biology.
If it smells, it's Chemistry.
If it doesn't work, it's Physics.
- My Physics Teacher
Fixed:
If it doesn't work, it's our Robot up until that last few days of the build season.
Unread 18-02-2013, 21:47
FRC #0611
Any more questions?
ok, so for the constructor. I pass the slot that it's plugged into on the DigitalIO for the slot, but what do I pass for channel?
Unread 18-02-2013, 21:48
FRC #0611
A motorized car jack that stops working when it goes too low or too high
Unread 18-02-2013, 21:55
dheerm's Avatar
dheerm dheerm is offline
Drive Team and Head Programmer
AKA: Dheer Mirchandani
FRC #0224 (The Tribe)
dheerm will become famous soon enough
DigitalInput name = new DigitalInput(slot)
fill in slot with the slot on the DIO that the switch is plugged into and name with whatever you want to call it.
name.get() will return you the boolean indicating whether the switch is pressed or Unpressed. If it's wired right, true will be pressed and false will be unpressed
"All you need is duct tape and a dream"
Team 224:
District Champions @TCNJ w/ Team 56 and Team 293
8th alliance captain at MAR championships w/ (take a guess) , Team 56 and Team 293.
www.team224.com
Unread 18-02-2013, 22:35
FRC #0611
Thanks, guys! Limit switch is working
Unread 18-02-2013, 23:06
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Scissor jack? Very suave just to think of it.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 18-02-2013, 23:10
FRC #0611
Yup! We use it to change the angle of our shooter.
Unread 19-02-2013, 00:33
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Awesome! So are we
Here's ours:
https://sphotos-a.xx.fbcdn.net/hphot...42295922_n.jpg
https://sphotos-a.xx.fbcdn.net/hphot...83332209_n.jpg
https://sphotos-a.xx.fbcdn.net/hphot...17571241_n.jpg
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 19-02-2013, 01:44
arithehun arithehun is offline
AKA: Ari Falkner
FRC #3024
arithehun is an unknown quantity at this point
For some of you using command based programming, I noticed that the DigitalIOButton class wasn't working properly, so I programmed my own DigitalButton class using the very-functional DigitalInput class.
public class DigitalButton extends Button {
    private int channel;
    DigitalInput buttonInput;
    public DigitalButton(int channel) {
        this.channel = channel;
        buttonInput = new DigitalInput(channel);
    public int getChannel() {
        return this.channel;
    public boolean get() {
        return buttonInput.get();
