Go to Post A bunch of kids in prom dresses staring through telescopes must have been quite a sight! - BlondeNerd [more]
Unread 18-02-2013, 19:55
MarcusF MarcusF is offline
#0157 (Aztechs)
MarcusF is an unknown quantity at this point
Send a message via AIM to MarcusF
Jaguar can issue
We have an interesting problem maybe someone can help with, our robot has mech wheels and can bus with jags. When we are turning the jag leds quickly strobe between forward and neutral. Several times a second. Anyone ever seen this? We are using from WPI library.
Unread 18-02-2013, 20:52
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Re: Jaguar can issue
Does this happen if you have the robot lifted off the ground as well?
Do you hear clicking noises from the breakers tripping?
Unread 18-02-2013, 21:01
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
It probably isn't breakers tripping since the status light goes to neutral, not off.
Have you tried a simple program, your program might be resetting it somewhere. Have your program output what it thinks the motor voltage should be.
Is your firmware up to date?
Are you using the serial to jaguar bridge, or a 2can?
Does the driver station report any errors?
Do you have a 100-120 ohm terminator at the end of the chain? If you are using the serial to jaguar interface do you have a terminator on that end as well?
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
Unread 18-02-2013, 23:38
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Are you setting the motor in multiple places in the code. For example, is the Set Output function in Teleop and in Periodic tasks? If so, you have two fighting Outputs and the latest one to get called wins.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 19-02-2013, 08:43
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
I personally doubt it's a forgotten end terminator, as that (from my experience) usually manifests as the last Jag flashing yellow (no signal) and all others behaving normally.
This sounds a lot like a code issue. If you have one, grab your serial to CAN cable and BDC-comm the CAN network with a laptop and test each motor individually... if all test good, Something in the code is probably awry (motor being set in two places, etc.).
