Go to Post The 2008 team is not the 2007 team and won't be the 2009 team. Every year is a new year and a new opportunity for growth and development as a FIRST team. It's very cool. - JaneYoung [more]
Unread 19-02-2013, 01:40
arithehun arithehun is offline
AKA: Ari Falkner
FRC #3024
arithehun is an unknown quantity at this point
Conflicting Vision Target Lasers
So we are planning on targeting the vision target by searching for an RGB color that we shine using a laser. Pretty typical. Let's just say we use a blue laser. What if another team uses a green laser and points it at the same target? How would our program work then? It seems that I must be missing something because this would be a very big problem.
Unread 19-02-2013, 01:56
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Conflicting Vision Target Lasers
FYI, lasers in this context probably would not be allowed. Some other form of light source, ie, LED ring, would work perfectly fine and is legal.
As to your question, it's a tradeoff between tolerance and specificity. Making your accepted color range narrower would clean up your signal but make it more prone to failure due to lighting conditions, and vice-versa.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 19-02-2013, 03:08
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
If you're using an LED ring, keep in mind that the retro-reflective tape, by nature of its design, has a very narrow angle of reflection. I can be standing next to my team's robot, and not even see a hint of green reflecting off the targets from our LEDs. To see it at all I have to put my head quite close to the camera.
I code stuff.
Unread 19-02-2013, 09:31
AKA: Ari Falkner
FRC #3024
Oh, it does? Thanks! And I think our particular laser is legal, but I'll double-check.
Unread 25-02-2013, 15:36
yelk11 yelk11 is offline
FRC #3414
yelk11 is an unknown quantity at this point
where did you learn how to process? from a website or a mentor? and if from a website what website
Unread 25-02-2013, 22:03
DonRotolo's Avatar
Back to humble
FRC #0832
Hint: Most lasers cannot change their color.
Unread 26-02-2013, 09:18
FRC #3414
unless you use a filter, possible made a glass.
