Go to Post However, mentoring isn't for you. It's for the others. - Alan Anderson [more]
Unread 19-02-2013, 07:53
Re: Victor 888 "y" cable issues
Originally Posted by theawesome1730 View Post
I do not however understand how a victor running 1% output can put out 12 volts.
Was that measured unloaded?
I agree that the cause of this is almost certainly the added load of a second Victor affecting the rise and fall times of the PWM signal enough to land just outside the 888s deadband. Try calibrating the Victors while they are attached to the Y cable and I expect the problem will go away.
Unread 19-02-2013, 09:42
Here's a graph of an 884's output voltage vs input pulse width, with the output essentially unloaded (1500 ohms).
Unread 19-02-2013, 10:01
Racer26 Racer26 is offline
I found when working with 4343 that we had to calibrate our Victor 888's on the Y cables to get them to behave nicely. Took a few tries to get "off" to be "off" and not "on just a hair"
