Go to Post "If everything is possible, there is the possibility that something is impossible..." ::sigh:: :) - Kims Robot [more]
Unread 19-02-2013, 03:45
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Team3763 Adam can only hope to improve
Exclamation VEX Motor controller?
So, I've encountered a bump in the road.
How do I program the VEX Motor Controller 29 in LabVIEW? I've read how you treat it like Victor in begin, and I did this to no avail. Example images of how the code should look would be FANTASTIC, and I'm hoping we can sort out this hiccup before bag-and-tag tomorrow.
Unread 19-02-2013, 08:25
Re: VEX Motor controller?
Treat it in software like a Victor. Treat it in hardware like a servo. It needs to get its power from the Digital Sidecar, so you must install the power jumper for the PWM channel it's connected to.
Unread 19-02-2013, 12:27
Team 3763 Peter Team 3763 Peter is offline
FRC #3763
Team 3763 Peter is an unknown quantity at this point
We've programmed to specification, but the male connector from the VEX motor controller posed a problem, and we had to force a male connector to become a female connector; that might be what's causing problems, but everything else checks out fine. Is there any way to buy PWM's with female-only connectors?
Unread 19-02-2013, 12:34
There has been a short female-to-female PWM cable included in the Kit before.
Unread 19-02-2013, 12:55
FRC #3763
Somewhere within the past 4 years, we've probably misplaced those cables. If we clipped the pins from the male connector, and shaped the remaining bit to resemble the female connector, is there any chance that our creation would work? In our Labview code, we have the VEX programmed as a single motor Victor, and it's using a button on our joystick to operate. Is there anything potentially missing in code?
Unread 19-02-2013, 13:41
You can make whatever you like. I know a lot of teams get PWM cable components from Hansen Hobbies.
I wouldn't count on it.
Your code is probably okay. Did you check to make sure you had the servo power jumper installed on the Digital Sidecar?
Unread 19-02-2013, 13:50
Lead Programmer
The VEX is jumped on the DS, and the connector has secure connections. We'll test it with a multimeter later on, but I'm confident it works.
Begin.vi
Single Motor refnum get and an Open Motor Victor - DM 1 PWM 8
Teleop
Single Motor refnum set and a Set Motor Output, based off of a true/false case with a button. T = 1 F = 0
Finish
Single Motor refnum set and close.
Unread 19-02-2013, 14:55
I underlined a phrase in what you wrote. What does it mean?
Begin.vi
Teleop
Finish
Your get should be a set and your sets should be gets.
Unread 19-02-2013, 16:49
Lead Programmer
My mistake, that's what they are in LabVIEW
The VEX Motor controller is wired into PWM slot 8 and it is jumped.
Attached is said code.
Unread 19-02-2013, 17:19
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
on your male to female pwm issue. We always just cut the end of the controller off and solder pwm end on. Works every time
