Go to Post Oh the wonders that happen in Michigan competitions... ;) - delsaner [more]
Unread 02-18-2013, 10:16 PM
AKA: Brad
#0190 ( Gompei and the Herd)
Getting the SmartDashboard to display the camera feed
There have been some instability problems for some folks with getting the camera image up on the SmartDashboard. We have an experimental version of SmartDashboard that has a simple camera widget that you can add. The simple camera widget is only useful for viewing the feed either from your Axis camera or the RoboRealm web server - there is no OpenCV support associated with it.
This is intended for teams that only want to use the camera for getting the robot view through the camera.
If you would like to give it a try, there are directions for using it here:
https://wpilib.screenstepslive.com/s/3120/d/6pjvwt
Please post feedback on how it works for you and whether or not it is useful.
Thanks,
Brad
Brad Miller
Robotics Resource Center
Unread 02-19-2013, 09:59 AM
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
Re: Getting the SmartDashboard to display the camera feed
Brad
We are getting the smartdashboard , though it crashes sometimes, but the Labview one on the driver station does not work at all. We prefer that for playing the game.
I am assuming that if we can see it in smartdashboard then all is configured correctly.
We have spent many hours chasing this. Any suggestions?
