Go to Post You should qualify the same way you eliminate if you ask me. - sircedric4 [more]
Unread 19-02-2013, 10:52
AquaMorph's Avatar
AquaMorph AquaMorph is offline
Alumnus of 2059
AKA: Christian Colglazier
FRC #2642 (Pitt Pirates)
AquaMorph is on a distinguished road
Re: Running Loop in Parallel
Originally Posted by Omar View Post
Agree about the state machine!
But so for your code, I not sure you have it quite right.
Is the code with the two while loops "Move Down until limit switch" and "Angle" inside the "Set Angle Preset 1" subVI?
Do you expect the "Disable Limit" Boolean input to change while looping around the "Move Down until limit switch" loop? If so that will not work because "Disable Limit" will only have the value passed in when the subVI was called and not any new value from the joystick. To update from the joystick as it loops, you will need to put a Joystick Get inside the "Move Down until limit switch"
I'm not too sure just how this angle setting is to work. It seems you have a 'home' position (Top Angle Limit) that you move to start and then iterate around a 10+ms loop a number of times read from the Dashboard until you HOPE to be at the angle you desire.
You are correct on how the angle adjustment is going to work. It goes up until it hits the limit switch then goes down for a set amount of time. I am hoping to replace the time function with a gyro but I have been unable to get a good reading from the gyro.
I am currently not too worried about the "Disable Limit" not working but I may change it if need be but I believe it worked in its current state.
FRC Drive: Play Store FRC Manager: Play Store
Unread 19-02-2013, 11:08
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Have you looked into using a potentiometer? The gyro will drift over time and will be effected by bumps and bangs as you move around the field.
Omar
Unread 19-02-2013, 11:59
AquaMorph's Avatar
Alumnus of 2059
That just got brought up in this topic http://www.chiefdelphi.com/forums/sh...23#post1236323 I am going to look into it.
