Go to Post Smells like gracious professionalism in here... :) - marshall [more]
Unread 19-02-2013, 10:53
Mubtasim Mubtasim is offline
FRC #4797
Mubtasim is an unknown quantity at this point
Compressor is not working
We are having a problem with the compressor
The spike relay is orange; selenoid is communicating but the compressor never starts??
heres the code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Relay;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.Jaguar;
public class RobotTemplate extends SimpleRobot {
private RobotDrive robotDrive = new RobotDrive(10,9);
private Joystick Stick = new Joystick(1);
private Jaguar Shooter = new Jaguar(5);
private Jaguar Loader = new Jaguar(6);
private Compressor compressor = new Compressor(2,2);
private Solenoid pistonUp = new Solenoid(1);
private Solenoid pistonDown = new Solenoid(2);
//Relay spikeRelay;
//private Relay spikeRelay = new Relay(2);
// public void robotInit() {
//spikeRelay = new Relay(2);}
public RobotTemplate() {
getWatchdog().setExpiration(0.5);
//spikeRelay.set(Relay.Value.kOn);
compressor.start();
//compressor.setRelayValue(Relay.Value.kForward);
public void operatorControl() {
getWatchdog().setEnabled(true);
while (isEnabled() && isOperatorControl()) {
getWatchdog().feed();
// robotDrive.setSafetyEnabled(false);
robotDrive.arcadeDrive(-Stick.getX(), Stick.getY());
robotDrive.setInvertedMotor(RobotDrive.MotorType.k RearLeft, true);
//spikeRelay.set(Relay.Value.kForward);
if (Stick.getTrigger()) {
pistonUp.set(true);
} else if (Stick.getRawButton(3)) {
pistonDown.set(true);
} else {
pistonUp.set(false);
pistonDown.set(false);
if (Stick.getRawButton(2)){
Shooter.set(.75);
} else {
Shooter.set(0);
if (Stick.getRawButton(5)){
Loader.set(.75);
} else {
Loader.set(0);
Unread 19-02-2013, 10:57
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Compressor is not working
whenever you say
= new ##(parameters) (such as new Jaguar(1))
keep it all in your robot init function, because it has to run after the cRIO is done compiling.
also,
public RobotTemplate() will never run. it has to be public void robotInit()
Unread 19-02-2013, 12:52
FRC #4797
Didn't solve the problem, here is the simpler version of the code that we are starting all over from the begining (without messing with relay in the program):
private Solenoid pistonUP = new Solenoid(1);
private Solenoid pistonDOWN = new Solenoid(2);
public RobotTemplate(){
compressor.start();
* This function is called once each time the robot enters operator control.
while(isEnabled() && isOperatorControl()){
if(Stick.getTrigger()){
pistonUP.set(true);
}else if(Stick.getRawButton(3)){
pistonDOWN.set(true);
}else{
pistonUP.set(false);
pistonDOWN.set(false);
* This function is called once each time the robot enters test mode.
public void test() {
Unread 19-02-2013, 13:54
FRC #4797
Smile Re: Compressor is not working
Everything works nice and finenow. There was some complication withhardware.
Thanks
