Go to Post Remember everyone, during build season, if you mess something up..... In the words of Adam Savage... Failure is always an option! (and so is blowing stuff up) - J.Warsoff [more]
Unread 02-18-2013, 09:03 PM
RoboCat2005 RoboCat2005 is offline
AKA: Catlin Level
FRC #3659 (Mighty Patriots)
RoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to all
Solenoid Programming Help
Alright I have looked all through the threads and find where this problem has come up, and that it all gets solved in the code but no specifics on the fix.
Our situation is that the NI-9472 solenoid, in either slot 3 or 7 of the 8 slot cRio, none of the lights come on and when the code is ran an error code of solenoid module is not present.
We think the code is not wrote right and are pretty sure we just dont have it wrote properly. Can anyone help us. This is our last thing we need to test before bagging. Thanks for any and all help.
FRC Team 3659 Mighty Patriots- Mentor/Drive Team Coach(2015-)
FRC Team 3345 Metal Jackets- Build Team Mentor (2012-2014)
FRC Team 2969 Hurricane Robotics - Lead Mentor/ Drive Team Coach (2011/2012 seasons)
FRC Team 399 Eagle Robotics - Student Alumni (2002-2005)
2011 Alamo Regional - Xerox Creativity Award(2969), Referee
2012 Alamo Regional - Quarter Finalist
2012 Lonestar Regional -Semi-Finalist
2012 Lonestar Regional -Xerox Creativity Award Winners
Unread 02-18-2013, 09:15 PM
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Solenoid Programming Help
Remember the first slot in the 8-slot cRio is "Slot 0", and the last one is "Slot 7"....
Unread 02-18-2013, 09:29 PM
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Can you post your code and also is it the module on the cRio that doesn't have lights or the solenoid. You might have a bad module or solenoid breakout board or might not have it wired correctly because you should have lights on there that I know of.
Unread 02-19-2013, 11:01 AM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Rather than using 3 and 7 for solenoid modules, use 1 and 2
