Go to Post Also, I'm tired of the "FIRST is a simulation of the real world"-- it isn't. If the real world was like FIRST, there wouldn't be any need for this organization. - cadandcookies [more]
Unread 18-02-2013, 23:05
Keefe2471's Avatar
Keefe2471 Keefe2471 is offline
FRC #2471 (Team Mean Machine)
Keefe2471 is on a distinguished road
Class 1 lasers
There seems to be various definitions of class 1 laser online. Does the assembled intelligence of Chief Delphi believe that a spec. sheet with a picture and a bunch of documentation that says the laser is a class 1 laser according to the manufacturer would sufficiently satisfy the inspectors?
That said does anyone have a source of a class 1 laser for under 50-100$?
We have only found ones in the 150$ price range.
Thanks in advance.
Unread 19-02-2013, 00:25
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
Re: Class 1 lasers
Why do want a class one laser? What I've read is that the only way a laser would allowed be on the robot is if the laser was part of a laser gyro.
Prototype, Prototype, Prototype
Unread 19-02-2013, 00:27
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Class 1 lasers
ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.
Examples of items that will violate R08 include (but are not limited to):
A. Shields, curtains, or any other devices or materials designed or used to obstruct or limit the vision of any drivers and/or coaches and/or interfere with their ability to safely control their ROBOT
B. Speakers, sirens, air horns, or other audio devices that generate sound at a level sufficient to be a distraction
C. Any devices or decorations specifically intended to jam or interfere with the remote sensing capabilities of another ROBOT, including vision systems, acoustic range finders, sonars, infrared proximity detectors, etc. (e.g. including imagery on your ROBOT that, to a reasonably astute observer, mimics the VISION TARGET)
D. Exposed lasers other than Class I.
E. Flammable gasses
F. Any device intended to produce flames or pyrotechnics
G. Hydraulic fluids or hydraulic components
Teams should provide MSD Sheets for any materials they use that might be considered questionable during ROBOT Inspection.
You can use Class 1 lasers.
Unread 19-02-2013, 00:42
Keefe2471's Avatar
Re: Class 1 lasers
^^^^ Thanks for the citation. We have found a laser pointer in the shop to be of use in guesstimating the angle of our shooter is required to be at to make a shot. Anyone have a clue about definitions of laser classes or where to get a inexpensive class 1?
Unread 19-02-2013, 00:51
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
laser are classed according to there output power http://en.m.wikipedia.org/wiki/Laser_safety#section_4
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: Class 1 lasers
We actually looked into this a while ago; it wasn't me who did the research, so I'm sure the number I will give you isn't correct. That said, laser pointers are classified as something like a 3b class, and not a class 1.
Unread 19-02-2013, 00:54
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Class 1 lasers
Almost every laser pointer I've ever seen is class 3A. If you do manage to find one in Class 1, there is likely to be a clear label affixed to the product (laser labelling is pretty stringent). In combination with the spec sheets and manufacturer documentation, that should be more than sufficient for the inspectors.
Wikipedia is pretty accurate on the subject of laser classifications. (I've read several of the underlying standards, which say basically the same things, but in technical legalese.)
Unread 19-02-2013, 06:19
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Re: Class 1 lasers
Do be careful if you will expose a laser outside of your robot. If it shines in the eyes of drivers, spectators, or volunteers you will likely be asked to remove it for safety reasons.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 19-02-2013, 09:47
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Re: Class 1 lasers
Thanks in advance.
They have them for ~$100 on McMaster
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 19-02-2013, 10:03
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Re: Class 1 lasers
As long as the laser turns on and off as part of the robots system and it is class 1 you can use it. Be prepared to have to cover it up in the pit while doing testing. We used a vertical line laser last year to do alignment and we had no problem. As long as the documentation from the manufacturer says it's class 1 you should be fine.
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 19-02-2013, 10:05
Re: Class 1 lasers
Those all appear to be Class III and some Class II lasers.
Not safe or legal for FRC.
Perhaps you meant to link to a different McMaster page.
Unread 19-02-2013, 10:32
Keefe2471's Avatar
Re: Class 1 lasers
Thanks for your help. Could you tell me which laser you used last year? Thanks
Unread 19-02-2013, 10:45
Brandon Holley's Avatar
Re: Class 1 lasers
I believe http://www.mcmaster.com/#2073A21 is Class 1M. No idea what "1M" means versus just "1".
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 19-02-2013, 11:18
Re: Class 1 lasers
-Brando
Maybe he was talking about the laser mount being ~$100...
Unread 19-02-2013, 11:24
vhcook's Avatar
Reader of Things
AKA: Victoria
Re: Class 1 lasers
-Brando
1M means it's a broad-beam laser that's Class 1 for the naked eye but not safe (over class 1, not higher than Class 3B) when viewed through magnifying optics. I'm not sure whether FIRST would permit it, but considering that there's a possibility folks in the stands are using binoculars, I'm not sure I'd chance it.
