Go to Post Publishing your code and designs = good. - MrRoboSteve [more]
Unread 17-02-2013, 16:28
Volunteer, WPILib Contributor
no team (Waiting for 2021)
How to fix a problem spike
Today 2 of our spikes went bad, and we would like to know how to fix them if it is fixable. One of our spikes consistently lights up red, and another once consistently lights up green. I opened one of them up, and I cannot see any solder bridges, so I was wondering if it could be internal in the relay modules. Any ideas or should i just wait until tomorrow and call vex?
Team 4488 - Mentor 2013-2016
Unread 17-02-2013, 21:07
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Lightbulb Re: How to fix a problem spike
Team 4488,
In my experience as an engineer it is unlikely that 2 components have failed due to themselves.. Can you post a little more information about your wiring configuration, what you are trying to do and your software so we can possibly point you in a direction?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 17-02-2013, 21:46
They were hooked up to the compressor, and after a few minutes it is doing what i described. We know it is not a wiring issue because we hooked the compressor up to another spike and it works and is still working hours later. So we have it working now, but are just wondering what to do with the old ones.
Unread 18-02-2013, 18:46
So we now have a 3rd dead one out of the box. We will be calling vex tomorrow and see if they can help.
Unread 18-02-2013, 19:32
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
3 dead spikes sounds like an issue on your part. Can you describe your wiring, and please include pictures?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 18-02-2013, 20:54
I don't have pictures, but it uses 18 awg wire from a 20 amp breaker going to the spike, then the output is wired to powerpoles which then go to the compressor. Its wired correctly. Thats how we have done it for years. We are using the new smaller compressor. And as of now a new spike is working correctly wired the exact same way.
Unread 19-02-2013, 08:08
If you have not replaced the fuse in the spike with a breaker you have simply blown the fuse in each spike. The compressor draws significant current when it starts. It is legal and recommended that you replace the fuse on the spike used for the compressor with a 20 amp breaker.
Unread 19-02-2013, 12:08
We were using breakers in 2 of them, and a fuse in one of them. In the one the fuse was in it was still good and was not blown. Plus if we pull the fuse the light turns off like it's supposed to.
Unread 19-02-2013, 14:27
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
I believe I found a bad spike last night while trying to get our compressor running. The behavior i saw from the spike is similar to what the original post described. Here is what my experience was:
1. Using 20 Amp snap breaker in the spike. Using the Compressor class in WPILib. Before the robot was enabled, solid orange LED on the spike. Once the robot was enabled the Compressor code would turn on the relay on the DSC (confirmed, little green light lit up as expected) that the spike was connected to. This resulted in the LED on the spike turning off (no color).
2. Removed the compressor leads from the output side of the spike. No change. Spike LED still off.
3. Removed the pwm cable from the spike. LED turn RED. Measured -10V on the output of the spike.
Replaced the spike. All worked fine. I did notice the pins on the pwm were pretty mangled when i removed it from the spike the first time (step 3 above) and it is possible not all three pins were seated correctly and this may have had something to do with the failure of the spike.
Unread 19-02-2013, 14:56
Ok,
I am going to state this as it is not entirely obvious. The input to a spike uses the same cable (PWM style) but does not feed a PWM signal to the spike. If the spike is not changing state as the LEDs next to the relay outputs on the DSC, then the likely culprit is the PWM style cable. Unlike the PWM outputs that feed a Victor, the center pin is used for the relay outputs.
Theoretically, the spike should not lock to an output when the cable is pulled. So as you have found, the spike operated normally when replaced.
Unread 19-02-2013, 15:06
Ok,
Understand it is not a pwm signal and that we are just using the same cable that is used to transfer pwm signal to the other motor controllers.
Not sure I fully undestood. You are confirming that the spike was bad?
Unread 19-02-2013, 15:08
J,
I was making the statement for those who are lurking so there is better understanding.
Yes, it sounds like the spike was bad. However, there are more reports of spike failure than in any year before. It seems odd for something so simple.
Unread 19-02-2013, 15:20
Andy A. Andy A. is offline
Getting old
FRC #0095
J,
Al- I'll just mention here that I had a 'bad' Spike this year, as well. It had a constant red LED indicator, but no current.
I have no idea when it was manufactured, and I chucked it in the trash can after deciding it wasn't worth messing around with. I'll see if it's still there, and if you're interested do a post-mortem. I agree that it's an odd thing to have fail with any sort of regularity- I think i could count on one hand the number of failed Spikes I've seen in 10+ years.
Unread 19-02-2013, 15:25
I emailed VEX and they want to look at it because they think its weird that 3 failed. I've been in FRC for 4 years and I've never had a bad spike.
Unread 19-02-2013, 16:50
Andy,
The only failures we have had were pulled out tabs from over active use. I was able to repair with a soldering iron. No control failures that I can remember.
