Go to Post What no one knows is that I’m actually wearing fishnet stockings under this gown… as soon as they finish taking all of these darn photos I’m going to show Dave and Amanda who really has the best legs in FIRST!!! - MissInformation [more]
Unread 18-02-2013, 15:42
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
Axis M1011 camera out of focus
Hey guys,
We;re having an issue with our camera. The camera itself works fine, we can see the image on the dashboard, everything works, but the camera is really out of focus. Everything beyond maybe 5 inch's is really blurry.
I've searched online but I can't seem to find any way to fix it. I did find out that the camera has a fixed focus point, but last year it worked fine!
Any help would be greatly appreciated .
Thanks!
Unread 18-02-2013, 21:44
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Axis M1011 camera out of focus
Does the ring surrounding the lens rotate? If so, try using that to focus.
Unread 19-02-2013, 02:11
Nope! No spinning ring. We 'd tried that already.
Unread 19-02-2013, 05:49
The M1011 has a lens that screws in, but unlike the 206, it is calibrated and glued at the factory.
My guess is either that something is smeared on the lens, try cleaning it with a monitor wipe or soft lens cleaning cloth. Or, your camera received a big whack and the lens/sensor are not the right distance apart. Does it rattle if you give it a shake?
Greg McKaskle
Unread 19-02-2013, 14:55
Yeah, I believe someone might have dropped it pretty hard or it fell off the robot. It doesn't rattle... I'm guessing there's no way to fix it? We can still see things that are really close, and it would still kind of work to see the outlines of the goals, but it'd be nice if it was focused.
Thanks.
Unread 19-02-2013, 15:13
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
You could always try to disassemble and reassemble it. I've fixed a misaligned 601 many times that way.
Unread 19-02-2013, 15:18
Wild,
If it was dropped and things that are close are the only things in focus, two possibilities exist. The lens mount might have cracked or broken causing the back focus to be off or one of the lens elements shifted position inside the lens.
Unread 19-02-2013, 19:31
Alright, we took off the cover, and the lenses did shift. It was almost completely screwed off. We cut the glue off, screwed it back in, and put the cover back on. Good as new.
Thanks guys!
Unread 19-02-2013, 20:00
Awesome. I was hesitant to suggest it without supervision, but that is just what I wanted you to try.
Greg McKaskle
Unread 21-02-2013, 06:39
Glad that helped.
