#61
Re: Shooting full-court: The uprising of the human-loader shooters
We prototyped our deflector/diverter on 469s practice field, which was ironic. "Steal from the best, design the rest." but give credit at least. -Clinton- |
#62
Then there are those full court shooters who take full advantage of the rules of the protected zone.
#63
I love the mass of people who don't understand that you trying to use the protected zone as a way of baiting your opponent is itself a foul.
#65
I can't wait to see a "troll bot" whose only job is to stand 6 inches from the protective zone.
#66
I would say that if you are close enough to be repeatedly hit with a G30 that you are WAY closer than you need to be to actually block a full court shot from most robots who can shoot full court. |
#67
The way I understand it,
If full-court-bot(FCB) is in the protected zone shooting , and defense bot (DB) comes to block its shot: If FCB moves to go shoot at the pyramid and hits DB then the foul is DBs because FCB is just trying to play the game. If FCB moves solely to trigger the penalty then goes back to shooting then the foul is on FCB because they aren't trying to play a game they're taking advantage of a rule (which is against the rules) It's the "spirit and purpose of the rule" thing |
#68
There are a ton of discression based rules. Best to practice caution. But if I was a red and I saw FCB jerk forwards touch DB and then jerk back to shoot again I wouldn't call a foul on DB under the aforementioned guidelines
#70
At that point it would be a judgement call. if the referee saw an attempt to evade, then it would be unintentional, but if they rammed right into the bot, then that could be seen as intentional.
#71
If the defense is not moving they shouldn't be eligible for a foul. From an interpretation standpoint.
Again we should keep in mind these are voulenteer s and so your results may varry and it may be best to air on the side of caution Last edited by JohnSchneider : 19-02-2013 at 16:42. Reason: Removed first line for being a bad analogy |
#72
If the defense isnt moving, they are purposefully trying to impede the flow of the game; unless the robot is broke and/or e-stopped.
#73
Then what other qualification do you use to determine if the full court shooter or the defender is committing the foul. |
#74
I can almost guarantee that it will be called the same way it was last year with the lanes and the key. If you are touching the pyramid or loading zone and someone is playing defense close enough by that you can touch them while still touching the loading zone or pyramid, they will get a penalty every time as long you don't abuse it and hit them repeatedly over and over in a short time span, that is when G18-1 will come into play and not a second sooner. |
