Go to Post Although it took me a little while to find my niche in the program, every moment spent has been one great memory after another. - Amanda Morrison [more]
Unread 11-02-2013, 13:44
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Output Torque of CIMple Box with 2 CIMS
Hey guys!
My team is wondering about the maximum output torque of a CIMple box from last year's kit. We are considering using it as a winch to lift our robot, and we really can't afford to burn out our motors this late in the game. Any help would be appreciated!
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 11-02-2013, 13:51
Re: Output Torque of CIMple Box with 2 CIMS
Originally Posted by Whippet View Post
Hey guys!
How much torque do you need, and for how long? That's what will determine if you're going to burn out the motors.
Unread 11-02-2013, 14:58
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
We need it to output ∼ 200 lb-in for intervals at around 10 seconds, three times. That should be the only time that the gearbox is pulling the weight of the robot.
Unread 11-02-2013, 15:33
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
The CIMPle Box (am-0734) has 4.67:1 speed reduction ratio.
A CIM at maximum power will deliver a little more that 1.1 Newton-meter (10 lbf-in) torque at about 2600 RPM, running from 12V. A little while ago I posted some lab measurements of CIM temperature rise at maximum power.
To get 200 lbf-in at your winch, you will need to gear down the CIMPle Box output. To avoid working the CIM past its peak power point, you should use about 5:1 reduction after the gearbox.
Edit: using two CIMs you will need less reduction after the gearbox, maybe 2.5:1 will be OK. Push it to 2:1 if you feel lucky. But as Ether said above, without reduction after the gearbox, it's not happening.
Richard Wallace
since 2003
Unread 19-02-2013, 18:10
yash101 yash101 is offline
AKA: null
Thumbs up Re: Output Torque of CIMple Box with 2 CIMS
Our robot also has a winch. We are using a CIMple box too and there is only one CIM. It is slow, but it winches up out 110 pound robot with quite some thrust. I think you might only need one. However, you were saying that there is 200 pounds needed to be lifted, then two CIMs would probably be needed. It should give enough torque.
