Go to Post thats like having 24 young men going wild for 2 minutes - thats how much power is available during a match. - KenWittlief [more]
Unread 19-02-2013, 20:00
IronBenderII IronBenderII is offline
FRC #3859
IronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond reputeIronBenderII has a reputation beyond repute
Exclamation Re: Help 2013 Robot won't run
How did this turn out? We are having the same symptoms as the OP. Our code worked 2 days ago and now we're getting an error that no robot code is running (but we have a green light on the DS for robot code).
Any help is greatly appreciated.
Jack Covert
Team 3859
wolfpackrobotics.org
Unread 19-02-2013, 20:08
The errors and warnings are timestamped. The message may be true at time t0 and then the code finishes loading and the LED comes on. Based on robot behavior, do you believe the code is running, or not?
Greg McKaskle
Unread 19-02-2013, 20:12
FRC #3859
Our programmer (Joe) says he believes the code is running. He probed a wire inside the main robot loop and he says non of the wires are executing.
Jack Covert
Team 3859
Unread 19-02-2013, 20:16
FRC #3859
If you are willing/able, you could call me/my programmer @ 916-949-9626
Jack Covert
Team 3859
Unread 19-02-2013, 20:45
FRC #3859
We just patched the CRIO, crossing our fingers and testing. Still not sure why this would pop up all the sudden...
Jack Covert
Team 3859
Unread 19-02-2013, 20:53
FRC #3859
No love on CRIO patch...
Jack Covert
Team 3859
Unread 19-02-2013, 21:39
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Could you verify that the code is uploaded in a way such that the code runs on start-up (this option is available in the imaging tool)?
Try running the code instead of deploying it then enabling it from the driver station (connect using ethernet).
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 19-02-2013, 22:31
FRC #3859
Hi there. It does run on startup and we have been running it (not deploying it). At this point we are re-writing the code one function at a time and testing. Going to be a late night...
Jack Covert
Team 3859
Unread 20-02-2013, 15:31
mrscience21's Avatar
mrscience21 mrscience21 is offline
Joe Sandoval
AKA: Joe S.
FRC #3859 (Wolfpack Robotics)
mrscience21 is an unknown quantity at this point
Hello from Team, 3859
After rewriting all of our robot code we discovered the original source of the problem was in our ADXL Accelerometer's interface to the I2C port on our Digital Sidecar. My guess is that the device was malfunctioned and was overloading the digital sidecar, forcing the C-RIO to stop interfacing with the software requesting the malfunctioning interface.
Hope This Helps anyone else out there!
Joe Sandoval
Wolfpack Robotics FIRST Team 3859
Department of Programming and Electrical Engineering
