Go to Post Don't be too distracted by the shiny robots, and the games they play. Enjoy them, but keep your eyes on the real prize(s). - gblake [more]
Unread 13-02-2013, 14:46
MoMo MoMo is offline
FRC #1721
MoMo will become famous soon enoughMoMo will become famous soon enough
Deadband Help
Hello we have a working mecanum code but we need to add dead band for a little better control. can any one help?
#include "WPILib.h"
// Team 1721 mecanum code 2013 By: Zakary Tobine at 2/11/13 10:33am
// Needs to add 2 relays; one for motor for shooter; one for frishbee pusher
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Joystick stick; // only joystick
public:
	RobotDemo(void):
		myRobot(1, 2, 3, 4),	// these must be initialized in the same order
		stick(1)		// as they are declared above.
		stick.SetAxisChannel(Joystick::kTwistAxis, 3);// Add the 3rd axis
		myRobot.SetExpiration(0.1);// The time the motors stop moving after a value is sent
	void Autonomous(void)
		// Commented out till a later date
		//myRobot.SetSafetyEnabled(false);
		//myRobot.Drive(-0.5, 0.0); 	// drive forwards half speed
		//Wait(2.0); 				//    for 2 seconds
		//myRobot.Drive(0.0, 0.0); 	// stop robot
	 * Runs the motors with one joystick mecanum.
	void OperatorControl(void)
		myRobot.SetSafetyEnabled(true);
		while (IsOperatorControl())
		myRobot.MecanumDrive_Cartesian(stick.GetX(), stick.GetY(), stick.GetTwist());// Mecanum drive single joystick drive
		Wait(0.005);				// wait for a motor update time
	 * Runs during test mode
	void Test() {
START_ROBOT_CLASS(RobotDemo);
Unread 13-02-2013, 15:29
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: Deadband Help
I described the way our team has been doing it the past few years here.
Hopefully sooner than later we will create a wrapper class for joystick objects so it's easier for ourselves and others to use this in the future.
Let me know if you have any questions.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 13-02-2013, 15:59
FRC #1721
Re: Deadband Help
That looks great but where/how would I add that into my code?
Unread 13-02-2013, 20:15
kylelanman's Avatar
Programming Mentor
AKA: Kyle
Re: Deadband Help
Give the following a try. I have a more object oriented version but don't have a robot to test it on so I don't want to distribute it yet. If it gives you any problems you can't figure out let me know. I don't have WindRiver handy to compile it but it should build.
In order to apply a dead band to a given axis you just need to pass the result of get axis method into InputShape. Then use the result that InputShape returns where you were using the get axis methods.
ex.
float x = InputShape(stick->GetX());
#include "WPILib.h"
const char inputShape[255] = {0,1,3,4,5,6,7,9,10,11,12,13,15,16,17,18,19,21,22,23,24,25,27,28,29,30,31,
	        33,34,35,36,37,38,40,41,42,43,44,46,47,48,49,50,52,53,54,55,56,58,59,60,61,62,
	        64,65,66,67,68,70,71,72,73,74,76,77,78,79,80,82,83,84,85,86,88,89,90,91,92,94,
	        95,96,97,98,100,101,102,103,104,106,107,108,109,110,112,113,114,115,116,117,
	        118,119,120,121,121,122,123,123,124,124,125,125,125,126,126,126,126,126,127,
	        127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,
	        128,128,128,128,128,129,129,129,130,130,131,131,132,133,133,134,135,136,
	        137,138,139,140,141,142,144,145,146,147,148,150,151,152,153,154,156,157,158,
	        159,160,162,163,164,165,166,168,169,170,171,172,174,175,176,177,178,180,181,
	        182,183,184,186,187,188,189,190,192,193,194,195,196,198,199,200,201,202,204,
	        205,206,207,208,210,211,212,213,214,216,217,218,219,220,221,223,224,225,226,
	        227,229,230,231,232,233,235,236,237,238,239,241,242,243,244,245,247,248,249,
	        250,251,253,254,255};
float InputShape(float userValue)
		int iUserValue;
		iUserValue = (int)(userValue * 127);
		iUserValue += 127;
		iUserValue = inputShape[iUserValue];
		userValue = iUserValue - 127;
		userValue /= 127;
		return userValue;
public:
	RobotDemo(void):
			float y = InputShape(stick->GetY());
			float t = InputShape(stick->GetTwist());
			myRobot.MecanumDrive_Cartesian(x, y, t);// Mecanum drive single joystick drive
	void Test() {
Unread 15-02-2013, 09:40
FRC #1721
Re: Deadband Help
It looks good. but this is the error we are getting when trying to build it...
C:/WindRiver/wrwb-debugmode-workspace/SimpleTemplate/MyRobot.cpp: In member function `virtual void RobotDemo::OperatorControl()':
C:/WindRiver/wrwb-debugmode-workspace/SimpleTemplate/MyRobot.cpp:69: error: base operand of `->' has non-pointer type `Joystick'
C:/WindRiver/wrwb-debugmode-workspace/SimpleTemplate/MyRobot.cpp:70: error: base operand of `->' has non-pointer type `Joystick'
C:/WindRiver/wrwb-debugmode-workspace/SimpleTemplate/MyRobot.cpp:71: error: base operand of `->' has non-pointer type `Joystick'
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** [SimpleTemplate_partialImage/Debug/Objects/SimpleTemplate/MyRobot.o] Error 1
Build Failed in Project 'SimpleTemplate' (Process Exit Value was 2): 2013-02-15 09:38:49 (Elapsed Time: 00:06)
Unread 15-02-2013, 09:43
FRC #1721
Re: Deadband Help
Alright i just fixed it. All i did was instead of stick->get... i did stick.get..
thanks!
Unread 15-02-2013, 15:47
kylelanman's Avatar
Programming Mentor
AKA: Kyle
Re: Deadband Help
Sorry about that. Glad you were able to figure it out. I guess that's what I get for copy and pasting.
Unread 16-02-2013, 17:32
FRC #1721
Re: Deadband Help
How would you adjust the dead band in this?
Unread 16-02-2013, 19:22
Re: Deadband Help
Let "J" be your joystick value, in the range -1 to +1.
Let "d" be your desired +/- deadband.
Let "out" be your modified joystick command (incorporating the deadband).
Then:
if (J>d) out = (J-d)/(1-d);
else if (J>-d) out = 0;
else out = (J+d)/(1-d);
"d" is the deadband tuning parameter in the range 0 <= d < 1
Unread 16-02-2013, 23:51
kylelanman's Avatar
Programming Mentor
AKA: Kyle
Re: Deadband Help
You would need to re create the array. We have a spreadsheet that does it somewhere I think. That is 6 year old code that we've been using as is.
Unread 17-02-2013, 09:36
Re: Deadband Help
Then:
Attached is a graph of what the above code produces for d=0.2:
Unread 19-02-2013, 19:33
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Re: Deadband Help
Another way to create deadzone-behaviour is to square the joystick X, Y, or Z value (and preserve the original sign, so a negative joystick value gives a negative result). For example, a js value of 0.5 gives a square of 0.25, but the maximum value of 1.0 still gives 1.0.
The way I learned this is an example of why I love to be a mentor. I'd written the algebra to implement a dead zone and with two slopes - it was complicated and when I tried to teach it at a WRRF programming workshop I confused most of the students. Afterwards a student (I think from FRC1700, Gatorbotics) told me about the square trick - it did what I wanted and was far easier to teach and implement.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 19-02-2013, 20:11
Re: Deadband Help
Or use a simple function as shown in the attachment and you can adjust the sensitivity to suit your taste.
Name:	sensitivity adjustment.png
