Go to Post "Well-resourced" teams with "deep pockets" don't just spring up, they are usually the result of a lot of hard work. - artdutra04 [more]
Unread 19-02-2013, 20:36
treeturtle1 treeturtle1 is offline
FRC #1780
treeturtle1 is an unknown quantity at this point
Solenoids not firing
Greetings Friends,
Our solenoids are wired and coded, but do not fire when the robot is enabled. The green lights flash and change as the firing buttons are pressed on the solenoid breakout. The code seems sound and have worked for us before. When pressed manually, the solenoids work just fine, just not with electronic or coded cues. How should I proceed?
Thanks,
1780
Unread 19-02-2013, 20:46
BOSS BOSS is online now
FRC #2883
BOSS is on a distinguished road
Re: Solenoids not firing
I would first look at the wiring, how did you wire this to the breakout? Is the solenoid light on when you fire the solenoid? try to power your solenoid with 12v supply and see if it fires manually.
Unread 19-02-2013, 21:14
FRC #1780
I wired from the lower half of the PD board directly to the WAGO terminal on to the breakout. The solenoids signal cords are 2 pin and wire directly into 12v receptors, but no lights show, and none fire by code, but fire manually. We just switched the 12v solenoid receptor to a 24v solenoid receptor and nothing changed. Again the green lights on the cRIO breakout change as I press the button to fire the solenoids, but nothing happens, neither the initial settings for the solenoids when the robot is enabled.
