Go to Post Either way, I'll stay a FIRSTer for life. =) - Adare180 [more]
Unread 19-02-2013, 20:39
Re: Problems With Victors
Originally Posted by 3175student17 View Post
the robot was fully operational until Saturday night.
Is software the ONLY thing you changed since it was last working?
Unread 19-02-2013, 20:43
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
We have changed the PWM cables, 4 Victors, the cord that connects the sidecar to the cRIO, the code, and the connection (we tried going with Ethernet instead of Wireless).
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 19-02-2013, 20:50
Let me re-phrase that.
Let t0 be the last time it was working.
Let t1 be when you first noticed it was not working.
What changes did you make between t0 and t1?
Unread 19-02-2013, 21:06
Thank you for the clarification. The only thing changed between those two times was the code.
Sorry if I am taking a while to reply, the internet in our team's room is very sketchy.
Unread 19-02-2013, 21:24
FlusteredRookie FlusteredRookie is offline
FRC #4423
FlusteredRookie can only hope to improve
Exclamation Re: Problems With Victors
I hate to hijack this thread, but my team is having a big problem with victors as well.
one of our mentors told us about the "magic smoke" in the motor controllers, but they started laughing afterwards, so none of us believed him. when we reversed the polarity of the wires to run the motors backwards (programming issue) it got out! how do we get the magic smoke back in?!?
Unread 19-02-2013, 21:35
Oh, there's a special tool for that.
It's called a credit card.
Unread 19-02-2013, 21:29
Then post this in the Programming forum, not Electrical, and you'll get more help. Make sure to post to C++, Java, or LabVIEW subforum, depending on what language you are using.
Unread 19-02-2013, 21:41
MathMaven MathMaven is offline
AKA: Elisha Sword
FRC #3175 (Knight Vision)
MathMaven is on a distinguished road
As lead programmer, please let me make a clarification:
We simplified the code to the simplest possible driving code. Several of our drive train Victors still failed to run. We even loaded two previous versions of our code that ran the same Victors perfectly in previous tests. Those same Victors still failed to run.
I believe this is conclusive evidence that the code changes were not the issue.
—Elisha Sword
2010–13: FRC Team 3175 (Knight Vision), student, lead programmer
2012–13: FRC Team 3175 (Knight Vision), lead website designer
2014: FRC Team 3175 (Knight Vision), programming mentor
“Who has not been amazed to learn that the function y = e^x, like a phoenix rising from its own ashes, is its own derivative?”
—Francois le Lionnais
Unread 19-02-2013, 21:55
With conflicting information it's difficult to troubleshoot.
"Several" of your drivetrain Victors "fail to run". How many is "several"? And what exactly does "fail to run" mean? Is the problem repeatable and is it always the same "several" that "fail to run"? What is the LED doing on the fail-to-run Victors?
Put your robot securely up on blocks and run the following tests.
Take a cheap handheld digital voltmeter set to an appropriate DC scale and probe the power input to one of the several fail-to-run Victors. If it's not roughly 12 volts then trace it backwards to find the problem. If it is roughly 12 volts then measure the voltage across the Victor's M+ M- power output terminals, using the same DC scale when the motor is being commanded full forward. If it's roughly 12 volts (or -12 volts) and your motor is not turning, you may have a bad motor, or you may have excessive friction in the drivetrain, or you may have 2 motors fighting each other. Post here for more details. If you don't get +/-12 volts, then pull the PWM cable from the Victor input and measure the voltage between the black and white pins. Post results here.
