How do i initialize the GearTooth sensor
I just received a GearTooth sensor today to program into the robot in order to keep track of RPM, but i have no clue how to set up the gearTooth. I read the documentation on the class but couldn't figure out what to do, here is what i currently have:
Declaration: Code:
GearTooth shootSensor = new GearTooth(3); Code:
shootSensor.setupSource(3); Code:
SmartDashboard.putNumber("Test:",shootSensor.getPeriod());
Re: How do i initialize the GearTooth sensor
Try replacing the setupSource() method with start(). This will start the GearToothSensor listening on port 3 for the counts.
You don't need to set up the port since you are passing the channel number (3 in your case) to the constructor. The GearToothSensor object will allocate a the port for you. Brad |
