Go to Post Sometimes the complex can be done very simply. - Cory [more]
Unread 02-19-2013, 04:00 PM
mgossman311 mgossman311 is offline
FRC #0415
mgossman311 is an unknown quantity at this point
Encoder Help
This year our team has decided to use the encoders. However I being one of two programmers for the team have never used the Java language and really need some help with programming the encoders.
Unread 02-19-2013, 05:06 PM
shank948 shank948 is offline
VP of Programming - 948
AKA: Stephen Shank
FRC #0948 (NRG (Newport Robotics Group))
shank948 is an unknown quantity at this point
Re: Encoder Help
I might be able to help. What exactly do you plan to use the encoder for? PID? Distance tracking?
As a starting point you might look at 2013 Java FRC API, specifically the Encoder class.
If it's green and slimy, it's Biology.
If it smells, it's Chemistry.
If it doesn't work, it's Physics.
- My Physics Teacher
Fixed:
If it doesn't work, it's our Robot up until that last few days of the build season.
Unread 02-19-2013, 05:19 PM
FRC #0415
Re: Encoder Help
We're are using it to track a distance between the starting point of autonomous and as a reference when we go to shoot the frisbees. If you could help, that would be great.
Unread 02-19-2013, 09:13 PM
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Encoder Help
You need to create the encoder objects using the constructor to provide port numbers:
Encoder enc;
enc = new Encoder(3,4); // where 3 and 4 are the digital inputs for the 2 channels
enc.start();   // start the encoder counting
int count = enc.get() // get the number of counts
The count will be the number of counts that the encoder object saw. If you know how many counts per revolution (CPR), and the wheel size, and (possibly) the gear ratio, you can compute how far you've gone in "count" counts.
There is a convenience method in the Encoder class that will actually return the distance traveled by the wheel (getDistance()). To use it you first have to first compute the distance traveled per pulse. When you have that number, call enc.setDistancePerPulse(distPerPulse) to "calibrate" the encoder object.
Does this help or are you still unsure?
Brad
Brad Miller
Robotics Resource Center
