Re: Camera not displaying on FRC dashboard
Can your code use the camera?
Also make sure anonymous viewing is enabled if using a m1011 |
Dunno if the code can use the cam (Never tried, and probably won't need to because we have no autotargeting) and I have anonymous access enabled. I'm worried, because the camera is crucial to proper operation.
If your camera bandwidth is to high, i.e., using all the maximum defaults, then you won't get a picture on the Dashboard, but it will report bandwidth.
You must get the video stream bandwidth down under, at most, 5Mb/s. You do this by clicking on the Dashboard camera controls and:
http://www.chiefdelphi.com/forums/at...1&d=1360330560 |
