Go to Post sheesh, how much more of a nerd can I be? - Libby K [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 19-02-2013, 13:18
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
sparkytwd will become famous soon enough
Pure Python NetworkTables 2 client
For this year, I've been working with Team 3574 on doing vision processing on an embedded ARM board (Odroid U2). As part of that work I implemented a NetworkTables client in Python.
There is some roughness to it, it's not pythonic, it has no support for array types (couldn't create those in either Python or Java), has some weirdness about reading your writes (sometimes you won't, sometimes you will, you could read invalid data), and makes liberal use of sleeps to make sure events happen in sequence rather than explicit checking.
If that hasn't scared you off, the nice things about it are; its dead simple with a single constructor that takes your team number, and just 2 methods, getValue, setValue. Types are enforced through exceptions (so be careful in non test code).
If you use this only to read values, or be the only client updating another value, it should work just fine.
https://github.com/Team3574/2013Visi...c/nt_client.py
Unread 19-02-2013, 23:59
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Re: Pure Python NetworkTables 2 client
WOW ... I hope this works. I am using the ODRIOD-U2 as well. Need it for vision. I tried to SIP the c++ network tables per instruction I could not get it to work. I posted in that thread as to why. Thanks for this. Though I do want to get SIP working. If you find any bugs please update! I will let you know if I make any improvements or fix any problems.
Unread 20-02-2013, 13:20
sparkytwd's Avatar
FRC #3574
Will do. Kids were able to test updating the network tables from their vision processing script running on a laptop.
I've got a kernel compiled for the Odroid U2 with PS3 Eye drivers, if you need that.
Unread 21-02-2013, 03:37
No thanks I have logitech270 cam running on /dev/04 just fine.
Unread 21-02-2013, 13:49
sparkytwd's Avatar
FRC #3574
Awesome. The shipped kernel was missing the ov534 drivers, but I was able to compile a new version on the board.
We like the Eye camera as it has custom lens assemblies available, and after an event last year where they had stadium lighting directly behind the vision targets we decided to switch over to infrared.
Unread 22-02-2013, 00:57
That is very cool idea!
Unread 03-09-2013, 14:27
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Cool Re: Pure Python NetworkTables 2 client
Awesome! I like. I had to do some modifying to the code to get it to work on the receiving end though... (Not 100% following some of your code.)
I replaced the getValue with:
    def getValue(self, name):
        for i in self.tableValues:
            if self.tableValues[i].name == "/SmartDashboard/"+name:
                return self.tableValues[i].value
        return None
Which works for floats and strings, at least. setValue doesn't work, and I can't quite figure out how or why...
Definitely gonna use this in my Tk dashboard, though.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
