Go to Post 1/4" baltic birch plywood is most of our metal. - z_beeblebrox [more]
Unread 20-02-2013, 01:35
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Spikes with alternate control systems
Hello CD,
Since this build season is over, it is now time to start working on other projects (not before a HALO 1 LAN party!).
One project we are working on is resurrecting our 2012 bot with one of the old IFI systems. I've gotten the victors programmed and running fine, but now I just need to figure out how to program the spikes. Do any veteran members remember how this was done?
I would think that it would as simple as plugging in the spike to the relay bank of the Robot Controller, and mapping buttons in code, but whenever I do that (and toggle the relay1_fwd or relay1_rev on or off) nothing happens. I can tell because the indicator light on the spike does not change from solid orange even when the button reads a change in input.
Are there different types of spike (green, blue, yellow, etc)? Is there something missing?
Thanks in advance CD! Our first demonstration is in 2 days to our city board, and I would really love to show them what our robot can do!
Unread 20-02-2013, 01:46
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Spikes with alternate control systems
Looking back to our 2007 code, it seems that we set relays using
relay_fwd=1;
relay_rev=0;
Mind you, it has been 5 years since I have even attempted to code C++, and I may be completely wrong, but I believe it is actually looking for the boolean 1 or 0 instead of on or off.
I'm right 90% of the time, so why worry about the other 3%?
Unread 20-02-2013, 13:06
UPDATE:
When I take a multimeter to the relay pins on the IFI Robot Controller, the Pins show a change in voltage (0-3V for either forward or reverse) based on the button. So it looks like the RC and code is ok.
So the new questions are should the output be 0-5V for either relay? Or are spikes from the new cRIO control system different?
Thanks
Unread 09-03-2013, 23:21
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
The new Vex spikes use 5V current for the signal wires. Whether or not 3 will work, I do not know
Look up the data sheet.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
