Go to Post I continue in FIRST because I'm not looked down upon for not knowing how to do something, but held up because I want to learn. - LemmingBot [more]
Unread 20-02-2013, 01:44
ItsElectronic ItsElectronic is offline
Team Captain
AKA: Terence
FRC #4461 (RAMEN)
Team Role: CAD
ItsElectronic is an unknown quantity at this point
Help! Final Hours!
As the last few hours of the build season are spiraling down we, a rookie team, are facing speed bumps that could determine our performance. We need help on how to mount a top heavy vertical flat surface on a flat plane of aluminum. Thank you in advance for your future help.
Unread 20-02-2013, 01:46
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Help! Final Hours!
A picture of what you're trying to do would be helpful. I can't say much without knowing what you want to do but I assume you're mounting some kind of shooter. What sort of material is it built out of? Aluminium tube? C channel? T-Slot?
Unread 20-02-2013, 01:51
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Just guessing, but it sounds like they're trying to make something that will block frisbees and want to attach it to a flat surface. If so, some angled pieces of 2x4 to act as triangular braces could probably work in the last hour that you have.
Unread 20-02-2013, 02:04
dtengineering's Avatar
dtengineering dtengineering is online now
AKA: Jason Brett
Don't forget the witholding allowance... you could bring something to the competition with you and bolt it on there.
Jason
Unread 20-02-2013, 02:29
vikesrock777 vikesrock777 is offline
Georgia Tech RoboJacket
AKA: Casey O'Connor
FRC #5332 (Toaster Tech)
vikesrock777 will become famous soon enough
Jason
To expand on what Jason is pointing out with the specific rule from the game manual.
R21
Teams may bring a maximum of 30 lbs of FABRICATED ITEMS to each event to be used to repair and/or upgrade their ROBOT.
For Teams attending 2-Day Events, these FABRICATED ITEMS may be used during the Robot Access Period and/or brought to the Event, but the total weight may not exceed 30 lbs. FABRICATED ITEMS constructed during the Robot Access Period and bagged with the ROBOT are exempt from this limit.
The OPERATOR CONSOLE, BUMPERS, and any ROBOT battery assemblies (as described in R05-A) are exempt from this limit.
