#16
Re: Trouble with spike and camera
How do we create the "Forward" and "Reverse" for the Teleop.vi? We are getting a boolean input and output and we dont know what to replace it with.
#17
On the Relay Set, right-click on the input node and choose Create -> Constant
Then break the wire and drag and copy/paste it wherever you need to place it. |
#18
Here is the camera image btw for the person wondering.... It also freezes randomly. http://www.chiefdelphi.com/forums/at...2&d=1361311627 Last edited by hasin5 : 19-02-2013 at 17:10. |
#19
It expects us to put a boolean input (its orange - not blue) - therefore, we get an error when we connect it to the relay set.
#20
Start with a new Select and it will have several orange floating-point nodes and one green boolean node.
The first thing wired to an orange node will change all the nodes to that type color. Last edited by Mark McLeod : 19-02-2013 at 18:06. |
#21
we got the spike working!
now we need help with the camera -> we need to set it up for targetting. Last edited by hasin5 : 19-02-2013 at 18:04. |
#22
We had to restore our camera to factory settings and set it up again. Now it is not blurry, but we can not get an image to appear on the dashboard. Any ideas?
#23
I suspect the data rate on the dashboard is updating and you need to click on the dashboard camera setting and low the frame rate or up the compression until the communication is within the limits the router is imposing.
Greg McKaskle |
#24
We tried that and it doesn't work..
#25
Help me out with some symptoms, doesn't work isn't much to go on.
I assume you have a custom dashboard. If, open the diagram and probe some of the wires in vision to see what is running and what isn't. In particular, the Camera Read JPEG has an outer case structure, one for simulation, one real. On the real diagram, it reads from the camera and parses the string to convert the JPEG into an image. What is going on there? If the Mbps indicator is not zero, the camera is talking back but the issue is more likely with the activation of the vision component on that computer. You can use the NI License manager to try and activate it, or you can uninstall the NIVision stuff and reinstall the DS update. Greg McKaskle |
