Go to Post My opinion doesn't matter at inspection. - DonRotolo [more]
Unread 20-02-2013, 09:27
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Re: KOP Gyro steadily decreasing
Thanks for the responses, guys.
Originally Posted by Team3266Spencer View Post
Reset the gyro as often as possible in the code.
Originally Posted by MagiChau
I agree with resetting the gyro as much as possible.
As in every cycle of test/auto/teleopPeriodic()? I thought that resetting set your current point as the new reference frame.
By the way, MagiChau, thanks for the whitepaper. It is exceptionally informative.
Originally Posted by Greg McKaskle
As mentioned, gyros are not perfect or magic. They are a sensor circuit and are affected by a number of real-world issues such as electrical noise, temperature, and operating procedures.
I understand. My concern was that the drift was exceptionally steady, which I assumed meant a problem outside of the sensor.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 20-02-2013, 09:35
Yes. So you set the current point as your new reference... when the current point is your desired zero.
Unread 20-02-2013, 09:37
Free Agent
Hence my confusion. To reset every iteration of testPeriodic(), autoPeriodic(), or teleopPeriodic() would reset my current frame of reference every 20ms. When would you suggest resetting the gyro, so that the drift is minimized, but the reference is functionally unchanged?
Unread 20-02-2013, 09:47
Spencer said to reset it "as often as possible", not every 20ms.
It depends on the application. For example, if you're using it to measure the heading of the robot, you could have a reset button on the joystick that the driver could push whenever the robot is pointing straight downfield.
Unread 20-02-2013, 23:17
Free Agent
Thanks for the suggestions. Ether, for the purposes of autonomous driving, would you just ignore the sensor drift because of the short time span?
Unread 21-02-2013, 00:23
Most likely. If you have access to more than one gyro, you could test them and pick the one with the least drift.
Unread 21-02-2013, 08:20
Free Agent
Thanks for all the help!
Unread 20-02-2013, 09:43
Be aware that the paper was written years before the introduction of the cRIO and its FPGA. The FPGA handles all the integration of the yaw rate signal from the gyro. You don't have to write all that code shown in the paper.
