Go to Post So perhaps those that are so eager to complain might realize that if they spent a little less time complaining and a little more time analyzing the problem and developing solutions, then they might have a little less to complain about. - dlavery [more]
Unread 19-02-2013, 22:33
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
KOP Gyro steadily decreasing
We were fooling around with a gyro, but as we print gyro.getAngle, we've noticed the angle steadily increasing as the robot sits. We've had this problem before in previous years, but we can't remember what we did to mitigate the issue. Any suggestions?
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 19-02-2013, 22:35
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: KOP Gyro steadily decreasing
Reset the gyro as often as possible in the code. The gyro we use for targeting we reset right before we move the robot so there's less time for error to develop.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 19-02-2013, 22:44
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
The gyro naturally accumulates error due to drift. The getAngle() it sends back is an accumulation in rate of change of angle. Error accumulates every time the gyro finds this. I agree with resetting the gyro as much as possible. There is a good white paper on gyros as well that you should read if you haven't in the following link.
http://team358.org/files/programming...rFRCRobots.pdf
Unread 19-02-2013, 23:20
what rate does it drift? a few degrees in 15 seconds is a reasonable rate for an FRC gyro.
Unread 20-02-2013, 08:07
As mentioned, gyros are not perfect or magic. They are a sensor circuit and are affected by a number of real-world issues such as electrical noise, temperature, and operating procedures.
Electrical noise: The heart of the sensor is an element that affects the voltage of the circuit proportional to rotational movement. Electrical noise and power dips on the input circuit look like rotation.
Temperature: The sensor's gain changes with temperature. When you boot the robot, it calibrates. If the temperature changes substantially, the sensor's assumptions are off and it will increase drift. The data sheet should indicate the amount of the temperature effect.
Procedures: It is important that the robot be steady when the program boots because it is measuring for a few seconds to identify what voltage correlates to a rotation of 0. If the robot is moving at this point, the assumptions are wrong and the gyro will spin at the opposite of that "zero" rate.
Another procedural issue is that the gyro has an upper limit on rotation. If you exceed this limit, it under-reports the rotation and throws off your idea of where the robot is pointing.
With all of these issues handled correction, it will drift, but for short periods of time, like during auto, or when aiming, you can use it for relative turning measurements.
Greg McKaskle
Unread 20-02-2013, 09:27
Free Agent
Thanks for the responses, guys.
As in every cycle of test/auto/teleopPeriodic()? I thought that resetting set your current point as the new reference frame.
By the way, MagiChau, thanks for the whitepaper. It is exceptionally informative.
I understand. My concern was that the drift was exceptionally steady, which I assumed meant a problem outside of the sensor.
Unread 20-02-2013, 09:35
Yes. So you set the current point as your new reference... when the current point is your desired zero.
Unread 20-02-2013, 09:37
Free Agent
Hence my confusion. To reset every iteration of testPeriodic(), autoPeriodic(), or teleopPeriodic() would reset my current frame of reference every 20ms. When would you suggest resetting the gyro, so that the drift is minimized, but the reference is functionally unchanged?
Unread 20-02-2013, 09:43
Be aware that the paper was written years before the introduction of the cRIO and its FPGA. The FPGA handles all the integration of the yaw rate signal from the gyro. You don't have to write all that code shown in the paper.
Unread 20-02-2013, 09:47
Spencer said to reset it "as often as possible", not every 20ms.
It depends on the application. For example, if you're using it to measure the heading of the robot, you could have a reset button on the joystick that the driver could push whenever the robot is pointing straight downfield.
Unread 20-02-2013, 23:17
Free Agent
Thanks for the suggestions. Ether, for the purposes of autonomous driving, would you just ignore the sensor drift because of the short time span?
Unread 21-02-2013, 00:23
Most likely. If you have access to more than one gyro, you could test them and pick the one with the least drift.
Unread 21-02-2013, 08:20
Free Agent
Thanks for all the help!
