Go to Post You could mount a small Black Hole on the top of your bot, and park it in front of the center goal - that would work...just keep your human player away from the event horizon. - KenWittlief [more]
Unread 18-02-2013, 20:49
rhp3794 rhp3794 is offline
rhp3794 is an unknown quantity at this point
Exclamation crio help
hey we need help we were making some tryouts an practices for drivers, we hit a wall and the negative current cable of the crio was disconnected an now our crio isnt getting energy
what can we doooo????
Programming Leader
Team 3794
WinT
Unread 18-02-2013, 20:52
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: crio help
Did you reconnect the cable?
Unread 18-02-2013, 20:53
Re: crio help
yes, was that a bad idea????
Programming Leader
Team 3794
WinT
Unread 18-02-2013, 20:56
plnyyanks's Avatar
AKA: Phil Lopreiato
Re: crio help
Not necessarily. Can you take a multimeter and probe the power wires going to the cRIO? You should see 24 volts.
Unread 18-02-2013, 20:58
Re: crio help
we just made that and the multimiters mark the 24V
Programming Leader
Team 3794
WinT
Unread 19-02-2013, 07:46
Re: crio help
rhp,
You measure 24 volts at the connector when it is connected to the Crio? Just to be sure, the Crio must be isolated from the chassis of your robot. The case of the Crio is connected to the black power lead. If there is any other short on your robot, the power to the Crio will be affected. Does the LED on the Crio turn on when the robot is powered? Does the 24 volt LED on the PD come on when you power the robot? If all seems normal, there is a fuse internal to the Crio that may have opened or broke off the board in your crash. Most often the wire at the Crio connector has been pulled out of the connector and simply needs to be reterminated.
Unread 19-02-2013, 09:02
Re: crio help
we have already try that, the PD LED of 24V is on, but none of the Crio is on, we tried with the multimeter is marking the 24V and continuity, we have made sure any other cable touch the Crio, we didnt turn anything and let rest the Crio about 8 hours and when w tried nothing worked!!!
Programming Leader
Team 3794
WinT
Unread 19-02-2013, 09:08
Re: crio help
Another possibility is debris inside the cRIO chassis that shifted when you hit the wall causing an internal short circuit.
That can often be fixed by carefully opening up the cRIO chassis (screws on back) and cleaning out metal dust and fragments that have collected inside the case.
Unread 19-02-2013, 11:12
Re: crio help
rhp,
You were able to measure 24 volts with the connector plugged into the Crio? If so, try opening the case and inspecting for debris as Mark has suggested. If you still can find nothing, do you have a team close by that you can visit? Try your Crio on their robot and see if it changes. You may have to arrange for a repair/exchange of your Crio.
Unread 19-02-2013, 20:40
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Re: crio help
We've seen the cRIO malfunction when the power distribution board's 24v output is noisy. The output still read 24vdc on a multimeter but the cRIO worked fine on a different power distrib. board. You can try 24vdc from two batteries wired in series, or 12v for the 4-slot cRIO since its input voltage is 9-30 VDC (written next to the power connector).
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 19-02-2013, 21:12
FlusteredRookie FlusteredRookie is offline
FRC #4423
FlusteredRookie can only hope to improve
Re: crio help
Uhm, I have a question too... Our robot is way too heavy so we swiss cheesed our cRio... It still runs the code but we can't put any more code onto it. And it smokes when the battery is plugged in... But it still runs the code that's on it... Help!!
Unread 20-02-2013, 10:20
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: crio help
If this is true, it's time to get a new cRio:
R65
The Driver Station software, cRIO, motor controllers, relay modules, wireless bridge, and batteries shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.), with the following exceptions:
If you added holes to your cRio or removed material, it is not allowed to be used on the robot any more.
2016: Lake Superior WFFA
Unread 20-02-2013, 11:45
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: crio help
Flustered is not a rookie, nor is s/he particularly flustered as a troll.
I suspect.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 20-02-2013, 12:03
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: crio help
Wait what?
*Facepalm*
Please tell me this is a troll.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 20-02-2013, 12:17
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: crio help
Originally Posted by F22Rapture View Post
Wait what?
*Facepalm*
A quick search of TBA yields that team 4423 does not exist. So yes, (s)he's a troll.
Academic Student (Forever)
