Go to Post I can tell you that I feel happiest when I am giving or doing for others. I do not expect anything in return but just knowing that I can make things better, in my small way, makes me happy. - Steve W [more]
Unread 19-02-2013, 21:45
LunarScratch LunarScratch is offline
FRC #1751
LunarScratch is an unknown quantity at this point
Need help finding connector online
We want to find more of these connectors to buy online, but we can't find out where to get them. Does anyone know where we can get these or something similar?The only model number we could find is Wieland ST 18/7. Thanks for your help.
Last edited by artdutra04 : 20-02-2013 at 16:38. Reason: please keep all embedded photos less than 1000ish pixels wide. Really wide photos make mobile browsing difficult.
Unread 20-02-2013, 12:08
Re: Need help finding connector online
Without knowing the application, I don't know what would be a "similar" part. What do you use them for?
Unread 20-02-2013, 14:10
FRC #1751
We use them to quickly connect and disconnect all motors from the jags.
Unread 20-02-2013, 16:33
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
I know Newark does not have them in stock but this is the item you want correct?
http://www.newark.com/wieland-electr...awg/dp/02M0770
If that's the correct item here you go for the female:
http://www.onlinecomponents.com/wiel...tml?p=11325143
Unfortunately the male mate of that connector (as shown in the PDF of Newark's print catalog) I found very little stock on anywhere. The best I can offer is a 13 day lead time:
http://www.galco.com/buy/Wieland/93.731.5053.0
Please keep in mind that Newark Electronics does stock some of the 3 and 4 contact versions of that item.
Unread 21-02-2013, 06:53
Lunar,
Might I suggest you move to Anderson Power Products. They would allow you to only remove one motor lead set instead of many. A great many of teams are already using them. The crimper is available from West Mountain Radio as well as other outlets and the pins and blocks are also easily available.
From an inspection standpoint, having mixed colors on the blocks is confusing even if it is only on the output side of the speed controllers.
