Go to Post Maybe if we build a giant wooden badger. - GaryVoshol [more]
Unread 19-02-2013, 19:52
Team 4457 Team 4457 is offline
FRC #4457
Team 4457 is an unknown quantity at this point
Re: Parts of robot failing?
Here is the revised code.
~There are always choices, some are just harder to make than others.~
Unread 19-02-2013, 21:18
FlusteredRookie FlusteredRookie is offline
FRC #4423
FlusteredRookie can only hope to improve
We are loosing air pressure in our pneumatic system really fast. We checked the connections but don't know what's wrong... Help?
Unread 19-02-2013, 22:34
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Pneumatics leak. It's a fact of life. If you put small amounts of water over your connections, you may be able to see which one is leaking. Other than that, you just have to work around it.
Unread 20-02-2013, 12:17
Originally Posted by Team 4457 View Post
Here are the photos.
I don't see any lights. Was the power off when you took the pictures?
Your Analog Breakout is not connected to power. It'll need 12 volts from the PDB in order for it to be legal show the battery voltage on the Driver Station.
The connector that I assume should be going to the Analog Breakout is instead wedged in next to the Digital Sidecar power connector. That can't be a good thing.
