Go to Post IMO the main idea behind FIRST is for the mentors and students to work together to produce a machine that the students could never have produced on their own. - Tim Sharp [more]
Unread 24-01-2003, 01:23
KennethToronto's Avatar
KennethToronto KennethToronto is offline
#0820 (Delta Tech)
KennethToronto is an unknown quantity at this point
Send a message via ICQ to KennethToronto
Shaft couplers
Does anyone know where I can find a 5/16'' clamp on coupling for the Atwood output shaft?
I've looked far and wide but I can only find 5/16'' set screw coupler (found at mcmaster)
North Toronto CI
Delta Tech Team 820 Robotics
Unread 24-01-2003, 01:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What if you took a couple (or a few) of McMaster Part No. 9964K11 and welded them together?
Unread 24-01-2003, 02:03
BillCloyes's Avatar
BillCloyes BillCloyes is offline
#0677 (The WireStrippers)
BillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura about
They can get rather pricey, but "trantorqes" might be a solution for you. They are available through small parts inc, (as trantorques) and mcmaster (as keyless bushings). We almost waited too long to get ours, as of earlier this week Small parts is back-ordered till almost Feb. Mcmaster, however, got them to us in 2 days. My team has used these for five or six seasons and I have personally experienced no real problems with them for the last three.
-Bill
Unread 24-01-2003, 02:40
#0820 (Delta Tech)
the reason I'm looking for a coupler (obviously) is because the output shaft on the Atwood is not long enough for our gearbox design...we have to extend the 5/16'' shaft.
hmm..the keyless bushing looks interesting
North Toronto CI
Unread 24-01-2003, 03:27
#0820 (Delta Tech)
Is there anything inherently wrong w. using a 5/16" set screw coupling to "extend" the length of the shaft?
North Toronto CI
Unread 24-01-2003, 08:51
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
It depends on how you define "inherently wrong". There is nothing illegal or immoral about doing so.
But as Woodie has said so often "Set screws inhale audibly". Basically set screws are ok to use for holding a key in place or possibly keeping a lightly loaded gear or sprocket from drifting on the shaft. They should not be used to transmit significant loads. Since this application is apparently for a drive, the loads will be significant.
Think about set screws for a moment. It doesn't seem all that great an idea to use an inclined plane (screw thread) to generate a normal force that is in turn used to generate a shear force that resists a torque. Dimpling the shaft can help, as it greatly increases the shear force geneated by the normal force. But a set screw and dimpled shaft are no match for a keyed shaft and sprocket or gear.
Christopher H Husmann, PE
"Who is John Galt?"
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Motor coupling archiver 2001 19 23-06-2002 23:35
Sketch of shaft for Robust Drill Transmission archiver 2000 2 23-06-2002 22:44
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
Connecting new gear to shaft? mnkysp6353 Technical Discussion 10 29-01-2002 05:12
