#16
Re: Team 1448 Robot "50 points in 50 seconds"
You're exactly right. And even if the defense is so good that they score no discs, they're still good for 3rd level climb, which really can't be stopped.
#17
#18
I don't get the 20pts only. If all else fails collecting the discs we can still do a 30pt climb.
#19
Awesome and so well done. That is almost exactly the design that we failed to pull off...
#20
I'm pretty sure, at least from what it looks like from your video, that your robot did extend past the 54" diameter. I hope this isn't the case since bag & tag was yesterday.
![]() Last edited by Lucas B. : 20-02-2013 at 16:30. |
#21
Any time you can cut off that 50 seconds will only increase your value and your ability to score those 50 points with defense. |
#23
Nope, we're very close at some points, but we're good. Thanks though!
#24
Great job and good luck at your events |
#25
Nice job.
Inauspicious music choice though...I was hoping it wouldn't end by falling off the bar ![]() |
#26
We've always been great at defense, but preventing a four-disk acquisition + back to the pyramid in 1:10 would be next to impossible. |
#27
I bring up defense because it seems to be the variable in this robots routine that is the hardest to control and is most likely to chew up significant time (having a good drive train/drivers always helps).
Good defense is never easy, but there are plenty of robots capable of it. I can imagine this robot being the primary scorer for many of its qualification match alliances. You will see good defense played on you this year. You would if I was on the opposing alliance. |
#28
Great job! What mechanism moves the hooks up and down? it looks very similar to our (sub-functional) mechanism.
#29
A motorized rack and pinion system raises and lowers the arms.
#30
"How many shooters can put up 30 points without interference?"
18 points autonomous plus four 3-point shots. 30 points. Piece of cake, defense or no. |
