Go to Post Feelings are like the laws of physics: if some one feels offended or alienated, then they are offended or alienated - it doesnt matter why you dropped a hammer, if it falls on someones head they will be hurt. You cant expect it to not hurt, because you did not intend to hurt them. - KenWittlief [more]
Unread 20-02-2013, 16:22
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Team 1448 Robot "50 points in 50 seconds"
Originally Posted by sircedric4 View Post
Everyone keeps bringing up intense defense on the climb and dumpers and I don't know why. With a climber and dumper you have to make exactly one trip across the field, where most shooters will be making several trips.
You're exactly right. And even if the defense is so good that they score no discs, they're still good for 3rd level climb, which really can't be stopped.
Unread 20-02-2013, 16:23
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Originally Posted by Manual
3.1.5.1 DISC Points
Points are awarded for DISCS SCORED in the GOALS per Table 3-2.
A DISC is considered SCORED in an ALLIANCE’S GOAL if any part of the DISC has crossed through the opening of the GOAL, is in the GOAL at the end of the MATCH, and is not in contact with any ROBOT from that ALLIANCE. GOAL openings are outlined in yellow in Figure 3-2 and Figure 3-3.$@#
You may want to consider having your arm be able to pull away from the dumped discs somehow at the end of the routine so it is unquestionable that they are scored. Wouldn't want them to settle in a position where they are touching the robot and not scoring you points!
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Bwalker's Avatar
Bwalker Bwalker is offline
FRC #1448 (Parsons Vikings)
Team Role: Driver
Bwalker has a spectacular aura aboutBwalker has a spectacular aura aboutBwalker has a spectacular aura about
Originally Posted by hill View Post
This robot, if impeded properly, will score only 20 points instead of 50 points.
That's a pretty significant point swing for only playing defense on a robot for one minute.
Edit:
There seems to be endless discussion of defense on full court shooters
I don't get the 20pts only. If all else fails collecting the discs we can still do a 30pt climb.
Unread 20-02-2013, 16:24
pfreivald's Avatar
AKA: Patrick Freivald
Awesome and so well done. That is almost exactly the design that we failed to pull off...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 20-02-2013, 16:25
Lucas B.'s Avatar
Lucas B. Lucas B. is offline
FRC #3641 (The Flying Toasters)
Lucas B. is an unknown quantity at this point
Unhappy Re: Team 1448 Robot "50 points in 50 seconds"
I'm pretty sure, at least from what it looks like from your video, that your robot did extend past the 54" diameter. I hope this isn't the case since bag & tag was yesterday.
Unread 20-02-2013, 16:27
Bwalker's Avatar
Team Role: Driver
Originally Posted by KrazyCarl92 View Post
You may want to consider having your arm be able to pull away from the dumped discs somehow at the end of the routine so it is unquestionable that they are scored. Wouldn't want them to settle in a position were they are touching the robot and not scoring you points!
Thanks for this! I'm very interested in this rule, and I will bring it up to the team.
Kellen Hill's Avatar
Kellen Hill Kellen Hill is offline
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
20 points is assuming you don't have time to get up to the 30 point level and make the dump.
Any time you can cut off that 50 seconds will only increase your value and your ability to score those 50 points with defense.
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 20-02-2013, 16:30
Bwalker's Avatar
Team Role: Driver
Originally Posted by Lucas B. View Post
I pretty sure, at least from what it looks like from your video, that your robot did extend past the 54" diameter. I hope this isn't the case since bag & tag was yesterday.
Nope, we're very close at some points, but we're good. Thanks though!
Unread 20-02-2013, 18:20
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
"Shutting down" robots is always so much more difficult then people realize. With the pinning rules and contact penalties it's really hard to do it effectively. Combine that with the fact that most alliances put their weakest partner on defense usually leads to ineffective defense. Its nice to think you won't lose to this robot but most teams will.
Great job and good luck at your events
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Nice job.
Inauspicious music choice though...I was hoping it wouldn't end by falling off the bar
2001-2004: Team 100
2006-Present: Team 254
Unread 20-02-2013, 18:51
pfreivald's Avatar
Agreed utterly.
We've always been great at defense, but preventing a four-disk acquisition + back to the pyramid in 1:10 would be next to impossible.
Team 1551
I write books, too!
Unread 20-02-2013, 22:37
Strategist
FRC #1746 (OTTO)
I bring up defense because it seems to be the variable in this robots routine that is the hardest to control and is most likely to chew up significant time (having a good drive train/drivers always helps).
Good defense is never easy, but there are plenty of robots capable of it. I can imagine this robot being the primary scorer for many of its qualification match alliances. You will see good defense played on you this year. You would if I was on the opposing alliance.
Unread 21-02-2013, 11:17
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Great job! What mechanism moves the hooks up and down? it looks very similar to our (sub-functional) mechanism.
Unread 21-02-2013, 12:16
Bwalker's Avatar
Team Role: Driver
A motorized rack and pinion system raises and lowers the arms.
Unread 21-02-2013, 18:40
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
"How many shooters can put up 30 points without interference?"
18 points autonomous plus four 3-point shots. 30 points. Piece of cake, defense or no.
