Go to Post The championship could be in a swamp infested with flying insects, and it would still rock the world :D - kristen [more]
Unread 16-02-2013, 00:34
clandry94 clandry94 is offline
AKA: Conor
FRC #3735 (KleinBOTS)
clandry94 is an unknown quantity at this point
cRIO noise?
Hey Chief Delphi,
We finished our electrical today and upon enabling the robot the cRIO makes a semi loud speaker tone. Does anyone know what causes this and how to correct it?
Thanks!
EDIT: We have the old, longer cRIO if that helps at all.
Unread 16-02-2013, 01:19
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Re: cRIO noise?
Are you sure it's the CRio and not the PDB? The PDB is known to make noise, I've never heard of the CRio making noise.
Unread 16-02-2013, 01:22
AKA: Conor
Re: cRIO noise?
Positive it's the cRIO. We unplugged it and the noise stopped, but came back when we provided it with power again. It's not like a buzzing electrical noise, but an actual speaker tone.
Unread 17-02-2013, 22:31
nitsuj27 nitsuj27 is offline
nitsuj27 is an unknown quantity at this point
Re: cRIO noise?
We have the same "noise" and found it to come from the analog card.
Unread 18-02-2013, 07:58
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Re: cRIO noise?
My guess is that it's actually the 24 volt power supply in the power distribution board that's buzzing. When you unplug the cRIO, the supply doesn't make the noise. Try changing out your battery and seeing if it stops.
Unread 21-02-2013, 07:10
Re: cRIO noise?
All of the above devices use a DC-DC converter that can make some noise. It is usually low level and very high in frequency so it isn't noticed over the rest of the robot noise. The convertors do make considerable noise when shorted or trying to do something they are not intended to do. If the Crio is making the noise, I would suspect it of having a problem. There is no speaker in the Crio. If the analog board is making the noise, I would check for miswired power to the board.
Unread 26-03-2013, 06:33
Burbelm Burbelm is offline
Burbelm is an unknown quantity at this point
Re: cRIO noise?
Originally Posted by clandry94 View Post
Hey Chief Delphi,
We finished our electrical today and upon enabling the robot the cRIO makes a semi loud buy speakers tone. Does anyone know what causes this and how to correct it?
Thanks!
cRIO does makes noise. I am not sure why it does that but sometimes it makes. Have you got any answer?
Unread 26-03-2013, 07:24
Re: cRIO noise?
There is nothing in the Crio that makes noise but the power supply on the analog bumper module may make some noise if there is an odd condition. If the Crio is emitting noises, suspect that there is an issue with the input power supply.
