Go to Post Designing for failure tends to encourage failure. Worrying about failure analysis during the competition can become a self fulfilling prophesy. Break your pots in the fall and learn how to keep them from breaking. - Mike Betts [more]
Unread 21-02-2013, 11:43
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
Re: pic: Team 1592 Ultimate Ascent robot, Buzz.
Originally Posted by dodar View Post
Yes it is a ground pickup and the human loader part interfaces with the ground intake to move frisbees to the shooter.
So the ground pick-up shoots the disc up and back out of the robot, and through the chute at the feeder station back to the human player? Does the human player then drop the disc back onto the top of the robot through the high slot?
This sounds kind of inefficient, if I understand correctly.
Getting your arm "weightless" is a great idea! Well done!
Do not panic! All is well!
- Kevin Bacon in Animal House
Unread 21-02-2013, 11:48
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
lol No, if you look at the robot you will see two blue rollers not in-line with the ground pickup; those are on their own smaller arm that rotates in-line if the shooter and the ground intake. That will rotate to be in-line with the ground intake and a disc will load in and then it will realign with the shooter and push it in to shoot. That arm(we call it the flipper) is also how we load from the feeder station. It flips out and then just reverses direction to load into the robot.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 21-02-2013, 11:49
chris1592's Avatar
chris1592 chris1592 is offline
Chris
chris1592 is a jewel in the roughchris1592 is a jewel in the roughchris1592 is a jewel in the rough
On the back of the robot is a chamber that rotates between feeding the shooter as shown in the picture and straight out.
When it is straight out the back, it serves 2 purposes. It serves as a method for the HP to load frisbees into the robot, and it allows one of our stowed frisbees to be loaded in the chamber and then rotated to be fed into the shooter.
I'll find a picture that can better illustrate the process.
Chris
Unread 21-02-2013, 11:53
chris1592's Avatar
Chris
Unread 21-02-2013, 12:07
neshera's Avatar
Nesher G. Asner
Team Role: Parent
Thanks, sorry for being so dense
Unread 21-02-2013, 12:08
dodar's Avatar
Nah its ok. I can see how what I said could have been mistakenly read.
Unread 21-02-2013, 15:58
John Sabath's Avatar
John Sabath John Sabath is offline
LabVIEW Software Developer
FRC #3792 (The Army Ants)
John Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to behold
Originally Posted by Kevin Selavko View Post
How do you flip your camera output?
There's a setting on the Axis cameras for it.
