Go to Post whatever you build, build it to last. - George1902 [more]
Unread 21-02-2013, 16:42
stuart2054 stuart2054 is offline
Controls Mentor
AKA: Stuart Sebright
FRC #2054 (TECH Vikes)
stuart2054 is just really nicestuart2054 is just really nicestuart2054 is just really nicestuart2054 is just really nicestuart2054 is just really nice
Re: Slow Climbers + Fast Pyramid Shooters
Originally Posted by EricLeifermann View Post
No we just realize its allot harder to shoot discs in the goal then "dump" them in. I'd rather be guaranteed 20 points from a dumper than a 10% chance at making 1 out of 6...
We tried shooting at the pyramid goal on a practice field and made 3 out of 4 a couple of times with little effort. So I believe shooting them in is very viable which I would not have believed had I not seen it.
Unread 21-02-2013, 16:48
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
Team Role: Electrical
Was defense being played on you?
Also how many teams designed their shooter to shoot at such a high angle? I know we didn't....
2012-2016 Wave Robotics Team 2826
Unread 21-02-2013, 17:11
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Also how many teams designed their shooter to shoot at such a high angle? I now we didn't....
Our team also got a similar result, 3/4 reliably with just humans eyeballing the angles. I'm not sure if we got video of it. We're touching the pyramid while making the shots, so defense is a non-issue.
Then again, we're designed specifically short-range and can run our shooter at any angle, so YMMV.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Our shooter is attached directly to our climbing arm, so we can actually shoot 90° from the floor.
More to Madison's point (What time is it?), the tricky bit will be if you are a 4/5 seed and can shoot from a number of positions, but have to pick from a field of potentially limited shooters (shooters that require a certain position) and a compatible climber. Assuming there is still a 30/50 point climber left (that takes the full 2 minutes), which do you pick first? I assume the climber first, and hope for a shooter on the way back, but how can you be sure your 2nd pick is compatible with your first?
Alliance selections are going to be /very/ interesting this year.
Last year, 1st pick was a good scorer, and 2nd pick was usually a triple balance partner, D bot, or an ok scorer. This year, there are many more things to consider. It will very much be a game of shooters vs climbers for the top seeds, and it entirely depends on the overall regional's capabilities.
Unread 21-02-2013, 17:21
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Originally Posted by Madison View Post
the best I've seen so far may take 45 seconds.
I already posted this, but you must not have seen:
http://youtu.be/CAehs2zvgDU
4143 will be climbing and scoring 5 point goals in under 30 seconds. We weren't even trying for speed in the video. I'm sure there will be other similiar outside corner climbers.
Unread 21-02-2013, 21:36
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
I think the important thing in qualifications is to actually have those discussions with your partners and make a plan before the match. If the teams treat each other as equals and are honest with each other, they should be able to reach an agreement on who should shoot and climb from where.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
