Go to Post If the GDC made a game that consisted of driving in a straight line, it would probably be the hardest game in FRC history. - themccannman [more]
Unread 21-02-2013, 22:00
Best Available Data
FRC #1778 (Chill Out!)
Re: NEW: OPR Android App
What dataset did you use to validate your OPR calculations?
Have you done any work to show that OPR on a partial event is useful? I looked at a regional in 2010 and found that that OPR really just wasn't worth looking at until Friday night, but would love to know if someone has done some more in depth work to show when it becomes useful, as the 1 regional I did is not exactly a big dataset.
Unread 21-02-2013, 22:10
stingray27's Avatar
stingray27 stingray27 is offline
AKA: Michael Ray
FRC #0027 (Team RUSH)
stingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to all
Yes I have. That was a very interesting route I went when I looked at that information, because like you, I was curious to see what it would do. First, the reason I put a limit on when you can calculate OPR is because I cannot invert the matrix sooner than that match. Second, the data isn't quite representative until around 50% to 75% of the regional is complete. I have noticed that most of the OPRs are to the extremes when calculated early. As the regional progresses, the OPRs tend to settle into more valid ranges. By Friday night however, I am confident it will be fairly accurate and should do a good job in predicting the rankings.
Michael Ray
Team RUSH 27
Driving Record: 93-64-0 Best Finish: Finalist (x4 FiM Districts)
Coaching Record: 16-7-0 Best Finish: Winner (Kettering Invitationa)l
Unread 22-02-2013, 01:05
Joining the 900 Meme Team
FRC #0079
Have you actually seen if OPR predicts better than a coin flip? I'd be curious at what point it exceeds the "pick random alliance" model or even the "pick alliance whose sum of rankings is lower" model.
Unread 22-02-2013, 01:01
dtengineering's Avatar
AKA: Jason Brett
Have you done any work to show that OPR on a partial event is useful? .....
I'd say that the "predictions" for upcoming match results will be a good way to determine when the data starts to become significant. It would be great to have an analysis of what fraction of the predictions are correct... it would be an excellent way to show at what point the OPRs become an effective indicator of match outcome.
But OPRs and scouting reports are always useful, if only for entertainment's sake!
Jason
Unread 01-03-2013, 16:01
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Jason
Older versions of OPRNet had a "self-check" mode for their predictor - if a regional was complete when someone asked for a prediction, it would tell you how good the predictions would have been if it had made them with the data available after each match. So it would say:
"After match 59, the predictions for matches 60-80 would have been 65% correct"
"After match 60, the predictions for matches 61-80 would have been 64% correct" (it varied a lot)
Generally what I found was that on friday night, saturday predictions based on the sum of OPRs for each alliance were 60-70% correct, which is obviously way better than a coin toss. This depends on the game though - OPR is better or worse depending on what the game is like. See the 1-hour mark of Karthik's presentation at champs last year for more details.
Post-event (aka once you know all the data) it was 80ish% correct, but that's a fairly worthless stat: once the event is over, anyone can get 100% of predictions correct!
Unread 01-03-2013, 18:44
Racer26 Racer26 is offline
Am I the only one finding that this app straight up doesn't work? I couldn't pull anything for BAE all day, while FRC Spyder was working fine.
Unread 01-03-2013, 19:28
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Bae results are working with todays update.
Thanks!
Unread 01-03-2013, 23:35
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
I'm not getting anything from the 'Team Statistics' choice for the Kettering University District event and even though they and BAE's Granite State Regional have played the same number of matches so far (52 through Friday night), BAE does give me OPR rankings. I also don't get any data for the other District event this week (Traverse City) even though I currently get OPR data for every Regional that played matches today.
Is there an issue with the way the districts are set up, either in the code or real life, that's causing this?
Unread 01-03-2013, 23:38
stingray27's Avatar
AKA: Michael Ray
You beat me to it I was just typing this up when you replied. Check for an update within the hour. Here is what I was typing though:
OPR FIRST 1.3 is now available. Plenty of bugs were fixed today - so I apologize for all of the inconvenience. Nice thing is, I believe I updated all of my bugs and it should work fairly well now. If I notice any others, I will update them as soon as possible. The revision from 1.2 to 1.3 fixed:
- Now can display match stats from District events (Ie Kettering and Traverse City). The district system made parsing different but I fixed it.
- The awards page didnt work but now does
Now on to functionality! Should be coming up shortly (the new cool functions ) but give me some time on that. Thanks!
Michael Ray
Team RUSH 27
Unread 01-03-2013, 23:43
AKA: Raa'Shaun H.
Thanks for the update, I didn't actually get 1.2 until about 2 hours ago so I wasn't sure what the issue was. I guess I'll be waiting until morning for the 1.3 update though. Google Play doesn't show it for me on my computer or my phone yet. Thanks for the update ^_^
Unread 02-03-2013, 01:22
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
I cannot get mine to update the Hub City tournament all day. I am trying tonight and still says update unsuccessful. I have updated to the latest version.
Norman
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 02-03-2013, 01:35
HayWire1569 HayWire1569 is offline
FRC #1569
HayWire1569 is a glorious beacon of lightHayWire1569 is a glorious beacon of lightHayWire1569 is a glorious beacon of lightHayWire1569 is a glorious beacon of lightHayWire1569 is a glorious beacon of light
Is there anything this awesome for apple products?
Unread 02-03-2013, 01:55
REVving up for a new season
FRC #2848 (All-sparks)
Norman
ditto.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 02-03-2013, 07:01
stingray27's Avatar
AKA: Michael Ray
Originally Posted by Greg Needel View Post
ditto.
Yep. Thank you. Bug is noted and I will take a look at it as soon as possible. Looks like when I fixed the mi districts I messed up hub city...
Michael Ray
Team RUSH 27
Unread 02-03-2013, 07:54
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
I don't show 1.3 being available on the play store. Can one "force" an update if the auto-update says nothing new is available?
Thanks for the app!
