Go to Post 5:20 - Lots of discussion about how FIRST pretty much wipes out the world of at least one object every year. - Andy Grady [more]
Unread 07-01-2002, 08:30
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
How many balls in the goals?
The remote kickoff in Novi didn't have a full complement of balls (at least not while I could get near the goal). Did anyone in New Hampshire try to fill up a goal to see how many balls would fit in it? If so, could you please post this info?
Thanks,
Chris
Unread 07-01-2002, 08:59
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Re: How many balls in the goals?
Thanks,
Chris
The questioned was asked during kickoff of how many balls could fit in a goal. They didn't give an exact number but said that it should be over 40 (ie it doesn't matter, all the balls fit).
Matt
Unread 07-01-2002, 09:04
Re: Re: How many balls in the goals?
Matt
It matters very much for strategy. For instance, if our alliance can only control one goal, what is our maximum score possible? The maximum score depends on how many balls you can fit in one goal.
-Chris
Unread 07-01-2002, 11:10
Like Matt said, the question was asked in NH and the answer was more then 40. There are only 20 balls on the field and a total of 10 in each alliance station.
Unless you are trying to do some type of wierd stacking, it doesn't matter if the goal can fit 50 balls or 200 balls, as there are only 40 balls on the field.
Unread 07-01-2002, 11:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I was under the impression that there are actually 60 balls in the game.
That is, there are 10 in each player station, and an additional 20 per side of the playing field.
Am I mistaken, and there are only 10 balls per side?
--Madison--
...down at the Ozdust!
Unread 07-01-2002, 12:13
Bill Whitley Bill Whitley is offline
Bill Whitley is an unknown quantity at this point
Send a message via AIM to Bill Whitley
There are 20 balls on each 'side' of the field. There are 0 balls on each 'end' of the field. Along with 10 in each player station, for a total of 60 balls.
-- bill
Unread 07-01-2002, 13:30
Todd Derbyshire's Avatar
Todd Derbyshire Todd Derbyshire is offline
Alumni
Todd Derbyshire will become famous soon enoughTodd Derbyshire will become famous soon enough
Right so you can only have access to 50 balls because 10 of them are in the hands of the other alliance
Unread 07-01-2002, 13:35
Madison's Avatar
FRC #0488 (Xbot)
Initially, you'd only have access to 50, but since the balls are 'neutral', you'd have access to the additional 10 balls when the opposing alliance decides to put them into play - if they decide to put them into play.
--Madison--
Unread 07-01-2002, 22:10
Elgin Clock's Avatar
FRC #0237 (Black Magic)
But if the goals are not team assigned then you can esentially gain control of all 60 balls at the end of the match, just pull all the goals with balls in it to your zone?
See... simple!
Unread 08-01-2002, 06:41
Adrian Wong Adrian Wong is offline
#0596 (SciClones)
Adrian Wong is an unknown quantity at this point
Send a message via AIM to Adrian Wong
Ah, but then you're only going to get 60 points or so (10 x 2 robots).
Unread 08-01-2002, 12:24
Pterrus's Avatar
Pterrus Pterrus is offline
#0177 (The Bobcats)
Pterrus is an unknown quantity at this point
Send a message via AIM to Pterrus
See... simple!
Not so simple. The other alliance will probably not be that dumb. For all practical reasons, I can't see more than 40 balls being scored total anyway, unless some team has a ridiculously efficient harvester.
Unread 10-01-2002, 03:42
Carolyn Duncan Carolyn Duncan is offline
The_C
Carolyn Duncan is a jewel in the roughCarolyn Duncan is a jewel in the roughCarolyn Duncan is a jewel in the rough
Re: Re: Re: How many balls in the goals?
-Chris
Not if your score is 3x the score of your oposing team
C~ya,
Carolyn Danielle
Thats C like the letter not like looking through your eyes or the large bdy of water! Just the letter C and yes it's on my birth certificate!
Unread 10-01-2002, 09:04
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
May the FORCE be with you....
Ahhh....but I see nothing in the rules outlawing the use of Jedi mind tricks....so I would not rule out our controlling even those balls in the opposition player station!
(Gee...maybe I'm showing too much of our strategy....huh?)
-Quentin
Team 4987: Megarams
Unread 10-01-2002, 12:00
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I dunno.. I think we're gonna see some ridiculous harvesters... and there will be matches where every ball is scored (maybe not all i one goal mind you)... As the strategies develop more and more people will be one upping each other simply by going for more and more balls...
imho...
JVN
Strategy Head
Clarkson University - Team 229
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Gus can put the big balls on the goals on the bridge!!! archiver 2001 0 24-06-2002 01:30
robot which can put balls on top of goals on bridge archiver 2001 4 24-06-2002 00:48
4 big balls on top of the goals archiver 2001 8 23-06-2002 22:27
goals and balls Strath General Forum 0 14-02-2002 22:34
