Go to Post I'm looking forward to seeing it in action! That is one sweet looking gun. The look on his face has me a tad worried though.... - Zholl [more]
Unread 18-02-2013, 00:15
OWilliamson's Avatar
OWilliamson OWilliamson is offline
FRC #2594 (NASKCO)
OWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of light
Can't View Original & Processed Image
On our dashboard the original camera image is showing perfectly, but when I add another indicator for our processed image it only shows the processed image and not the original. I put the two images on separate tabs but I'm still getting this issue.
Any ideas on how to make them both show up?
Unread 21-02-2013, 17:29
Re: Can't View Original & Processed Image
Can you post your code? There are a few things with the way that IMAQ handles images that could cause an issue.
Unread 22-02-2013, 00:41
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
two things right off the bat to check. Did you make sure there is two declared imaqs? one to display unprocessed ,and the second to display processed? Secondly, is your process display set to display binary image(assuming you are using a variation of the processing code FIRST sent out). Both are easy to forget, and with out both it is easy to accidentally process your imaq image meant as the original followed by neither showing because they are both binary images, which isnt labview's default output
Unread 22-02-2013, 01:28
FRC #2594 (NASKCO)
This is the first part of the project. I only have 1 IMAQ and it is for the host image. I kept the original image indicator but copied in the indicator for the processed image from the example project and put that in later in the code. Do I need to have 2 IMAQs to view them both?
Name:	2013 Dashboard Code Help.JPG
Unread 22-02-2013, 03:55
Yes. The IMAQ image is unlike other LV datatypes. Due to the large amount of data in an image, it acts as a refnum. Your diagram defines the allocation and destruction of images, and branching the wire doesn't create a new one for you.
To correct your diagram, create another image on the outside left of the loop and wire that into the destination of the threshold. That will preserve the original image so that it can be displayed.
Greg McKaskle
Unread 22-02-2013, 09:35
FRC #2594 (NASKCO)
So would I do it like this or do I need to have another Read MJPG with the original not connected at all? Also, do I leave the IMAQ as the RGB U32 like the original image?
Name:	2013 Dashboard Code Help 2.JPG
Unread 22-02-2013, 13:20
Good questions.
If you right click on the Image Threshold VI and choose Help, it will take you to the reference manual on this VI. It clarifies ...
Image Dst is a reference to the destination image. If Image Dst is connected, it must be an unsigned 8-bit image.
So, you don't need to get another image. Your diagram is very close, but make the dst be the correct type of image. If you run it the way you have it, you will receive runtime errors at that node.
Greg McKaskle
Unread 22-02-2013, 17:11
FRC #2594 (NASKCO)
I updated the dst to be U8, is that all I have to do? I can't test right now because I don't have access to the camera.
Name:	2013 Dashboard Code Help 3.JPG
Unread 22-02-2013, 17:21
You also need to make sure that both images have a unique name.
Unread 22-02-2013, 22:09
FRC #2594 (NASKCO)
I changed the name, is there anything else I need to change?
Name:	2013 Dashboard Code Help 4.JPG
Unread 23-02-2013, 09:28
Good catch. I missed the name conflict. That should be it.
Greg McKaskle
Unread 23-02-2013, 11:17
FRC #2594 (NASKCO)
Thanks for all the help, good luck to you guys going to competition!
