Go to Post but who knows what you might want to try next? - dlavery [more]
Unread 21-02-2013, 14:14
Generator of Entropy
FRC #2973 (The Mad Rockers)
Wiring a Flashlight, 2013 version
Copying this question from the photon cannon thread to a forum where the electrical guys can weigh in, and I didn't see anything in Q&A addressing this. 2 Questions:
1) It appears that this year because of R52 and Table 4-4 that you can't run a flashlight through a Spike relay - A flashlight doesn't appear to be a "Legal Power Regulating Device Use" since it isn't listed as an allowable load anywhere for the Spike. Agree?
2) It looks like wiring to a flashlight could be run directly from the 5V connector on the PD board per R39. Is this true?
Unread 21-02-2013, 14:24
Re: Wiring a Flashlight, 2013 version
Pointed out to me by someone else that the * under pneumatic solenoids in Table 4-4 discusses controlling multiple lights with a relay - is it covered by that?
Unread 22-02-2013, 09:38
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Originally Posted by R52
Each power regulating device may control electrical loads per Table 4-4. Unless otherwise noted, each power regulating device may control one and only one electrical load.
Emphasis mine.
To me, this seems to mean that if an electrical load is not enumerated in table 4-4, then it can be controlled using a power-regulating device, but only one of them per power regulating device (so multiple low-current lights could be powered by a single spike; only one high-current light could be controlled per spike. not sure what determines low-current vs high-current - probably whether the total current draw is under the max current rating of the spike).
R53 R54 says that custom circuits can't affect the power pathway of other custom circuits, but if you were to make a custom flashlight-like device that included a relay to switch it on and off, that seems like it would be legal to me.
Overall, seems like a question for the Q&A.
FRC 766, 2015-, Mentor
Unread 22-02-2013, 10:39
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
R53 is about solenoids. I think you meant R54, which says:
Custom circuits shall not directly alter the power pathways between the ROBOT battery, PD Board, motor controllers, relays, motors, or other elements of the ROBOT control system (including the power pathways to other sensors or circuits). ...
The "Custom circuit" in this case is just the flashlight (and the wire that goes between the relay and the flashlight). So, the custom circuit is not altering the power pathway to anything else, so it doesn't violate R54.
The text at the bottom of Table 4-4 says:
Multiple low-load, pneumatic solenoid valves or lights may be connected to a single relay module. This would allow one (1) relay module to drive multiple pneumatic actions or multiple lights. No other electrical load can be connected to a relay module used in this manner.
(emphasis mine)
So, it seems pretty clear that a relay to turn the flashlight on and off isn't violating R52 (Table 4-4) either.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 23-02-2013, 01:27
RyanCahoon's Avatar
Correct; thank you for the correction
Unread 19-05-2013, 07:50
AudreyWarren AudreyWarren is offline
AudreyWarren is an unknown quantity at this point
led flashlights through a Spike relay - A flashlight doesn't appear to be a "Legal Power Regulating Device Use" since it isn't listed as an allowable load anywhere for the Spike. Agree?
It seems wiring a flashlight is very tough job. Do you have any circuit diagram which could simplify bit more? Thanks in advance
Unread 24-05-2013, 13:06
JoshSmith JoshSmith is offline
LED Junkie
JoshSmith is an unknown quantity at this point
Do you have a particular flashlight in mind? I know what we did was use a spike relay to handle the on/off control and then connected that you a (fuse protected) DC-DC voltage regulator (product number BOB-09370 from sparkfun for the exact one). The voltage regulator was tuned to around 4.5 volts (Or something close to that) which matched what the LED required.
