Go to Post Wins = Attention Attention = Sponsors Sponsors = Money Money= being able to do more. a vicious cycle...but it is what it is - Protronie [more]
Unread 24-01-2003, 14:58
JLambert's Avatar
JLambert JLambert is offline
#0151 (Wild Cards)
JLambert is an unknown quantity at this point
Send a message via ICQ to JLambert Send a message via AIM to JLambert Send a message via Yahoo to JLambert
To help with the joystick sensitivity, you could add some code to create a "dead-zone".
Essentially, the robot would think the joystick is in the neutral position unless it is moved in a direction a certain amount.
'---------- Joystick Dead Zone -------------------------------------------------------------------------------
if ((p1_y > 137) OR (p1_y < 117)) then end_p1_y_dead_zone_adj
p1_y = 127
end_p1_y_dead_zone_adj:
if ((p1_x > 137) OR (p1_x < 117)) then end_p1_x_dead_zone_adj
p1_x = 127
end_p1_x_dead_zone_adj:
Try adding that before the part that says 1 Joystick Drive. It may help a bit.
Justin Lambert
02-03: Programmer Team #151
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Default Robot Code lvhsrobotics Programming 2 10-01-2003 16:55
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
