Go to Post Please think before you speak. - Cory [more]
Unread 20-02-2012, 12:00
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
AM Compressor versus Thomas Compressor
Anyone can confirm what the weight difference is between the compressor Andy Mark sells and the Thomas ones ? Also, is there a materially different output rate between the two. I'm also slightly concerned the AM might overheat given its reduced heatsinking and a 10% duty cycle rating.
Unread 20-02-2012, 12:52
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
Re: AM Compressor versus Thomas Compressor
The new compressor, gets really hot after prolonged use, I prefer the new compressor though, it is very small and very lightweight, I think the specs on it are the same as the old Thomas. I would say that the new one is about 1/2 the weight of the old Thomas.
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 20-02-2012, 13:15
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Please refer to this thread for more information about the new V Air Compressor.
http://www.chiefdelphi.com/forums/sh...ght=compressor
If you are talking about the new Thomas 215 than the V Air is about half a pound lighter but the Thomas is leaps and bounds better in terms of reliability, cycle time, and running temperature.
If you are talking about the old Thomas that were given in the KOP than the weight difference is about half.
Unread 22-02-2013, 17:56
de_ de_ is offline
AKA: Dave Edwards
The 215 is listed as having a 16amp running current and a 50 amp starting current. The starting current sure sounds like a show stopper for a 20amp rated spike.
Is anyone using the 215 in the competition ?
Unread 22-02-2013, 18:03
The spike is rated at 100 amps for < 2 seconds.
Unread 22-02-2013, 22:44
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
I forgot what the old Thomas compressor weighs but the Viair 90 series is 2.4lbs. Here is the full data sheet. http://www.viaircorp.com/90C.html It is carried by lots of retailers as it is a very popular unit.
Unread 22-02-2013, 23:29
omsahmad's Avatar
omsahmad omsahmad is offline
FRC #1595 (Dragons)
omsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really nice
We decided to use the old Thomas Compressor due to its duty cycle. Apparently the AM compressor in only 9%... So as other pointed out, it is not ideal for prolonged use (like to fill our 12-13 air tanks). Also, the AM compressor does not have a built in release valve, which has to be immediately "T-ed" off which adds a little weight.
Unread 23-02-2013, 03:41
Mr V's Avatar
FRC #5588 (Reign)
I found the specifications for the Thomas compressor here http://www.gd-thomas.com/product.aspx?id=12084&tp=p .
To summarize
Flow
Viair 1.03 CFM @ 0psi
Thomas .80 CFM @ 0psi
Max continous pressure
Viair 120psi
Thomas 100.1psi
Duty cycle
Viair 9%
Thomas Not rated
Max on time
Viair >3min 3sec
Thomas Not rated
Weight
Viair 2.4lbs
Thomas 4.4lbs
Outlets
Viair 1
Thomas 2
Current draw
Viair 10a
Thomas 10.5a
Check valve included ?
Viair Yes
Thomas No
Yes the external head temp of the Viair will get higher than the Thomas due to its lower thermal mass and the fact that it has more cooling fins to pull the heat from the compression chamber but that is a good thing since it likely means lower internal temps.
Unread 23-02-2013, 11:48
Originally Posted by Mr V View Post
To summarize
Flow
There's something wrong with the Viair spec sheet you used.
The Viair itself carries a label stating:
"Flow Rate @ 0 psi (13.8 volts): 0.88CFM"
The spec sheets of the two devices also do not appear to be comparable, because different criteria were used in the measurements, e.g., the VIair measurement is based on 13.8 volts, while the Thomas is based on 12v.
Somewhere around I have timed compression tests we ran with both the older Thomas model compressor vs. the VIair 90. I'll see if I can dig them up and post them.
Unread 23-02-2013, 12:09
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
I can't compare the technical specs (besides, it has been done 2-3 posts ago), but I prefer the new compressor. Its size and weight make it ideal for this year's smaller footprint, draws less power (never have we encountered electricity problems with it, unlike the Thomas compressor that draws so much power it shut our robot down in many occations) and makes less noise (which makes working withit that much more comfortable.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 23-02-2013, 16:30
Here's a test that was run on the same system/same fully charged battery/different compressors.
System held pressure for 5 minutes after test.
Thomas 405ADC36/12 (from 2009 kit)
VIAir 90 (purchased through AndyMark)
Ambient temp: 68 degrees
Volume (including hoses/tanks): 360 cubic inches
Battery voltage at start was 13.6v. During compression the voltage was ~12.4v (+/- .1v). At the end voltage was 13.02 for both.
-----------Thomas --------- VIAir
Time --- psi/temp ------ psi/temp
0 min ----- 0/68d ---------- 0/68d
1 min ---- 60/70d --------- 30/69d
2 min ---- 85/71d --------- 60/72d
3 min --- 110/74d --------- 80/73d
3:31 ---- 118/74d (cutoff)
4 min ----------------------- 100/83d
4:31 ------------------------ 118/85d (cutoff)
