Go to Post We're not behind, the rest of the world is ahead! Yeah. Thats it. - Curtis Williams [more]
Thread Tools Rating: Thread Rating: 16 votes, 4.50 average. Display Modes
  #31   Spotlight this post!
Unread 09-12-2011, 01:13
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: 2011 compressor
We ran the new 90c compressor with a 1gal tank + KOP tank though out the season and never had a single problem. The compressor always ran at least for half of every match we played.
Is there any better alternatives to the 90C or the Thomas that fits within the rules?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
  #32   Spotlight this post!
Unread 09-12-2011, 01:42
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: 2011 compressor
Personally, I have found that the new compressor does its job just fine, as long as you don't overheat it. We had to be careful while practicing to make sure that it stayed cool, but other than that, performance was comparable to our old compressor.
My recommendation for anyone who is running the new compressor is to pre-charge your pneumatics while practicing using a shop compressor (this is really easy to plumb into the release valve). This should avoid burning it up when you have to drain it every five minutes to modify a prototype.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
  #33   Spotlight this post!
Unread 09-12-2011, 07:31
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: 2011 compressor
Originally Posted by IndySam View Post
Having extra storage on board will not necessarily help here. The compressor will work just as hard to fill up the extra storage.
If you have enough storage that it won't need to run too much during the match you can monitor the compressor while filling in the pit so it doesn't overheat and burn up the piston cup.
Thank-you 294 & 67
www.bobcatrobotics.org
  #34   Spotlight this post!
Unread 09-12-2011, 07:35
Gdeaver Gdeaver is online now
FRC #1640
Re: 2011 compressor
If a tea team does not use the KOP compressor then make sure you account for it on the BOM. That Previous year compressor is expensive.
  #35   Spotlight this post!
Unread 09-12-2011, 17:46
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: 2011 compressor
Unfortunately last year, veteran teams who used their previous year's KOP compressors had to include their cost in the BOM; if you wanted to use a "free" compressor on the robot you had to buy the 2011 compressor.
http://forums.usfirst.org/showthread.php?t=17185
I guess we'll find out when we see the rules January 7th
  #36   Spotlight this post!
Unread 15-12-2011, 12:37
Mk.32's Avatar
AKA: Mark
Re: 2011 compressor
I spoke to soon.... our 90C compressor just died...
Like I said before it was under high load (1gal tank) for most of the matches.
Is the Thompson really that much better? Considering we need a replacement now...
  #37   Spotlight this post!
Unread 15-12-2011, 15:13
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: 2011 compressor
The Thomas 12v compressors (while heavier and larger) are significantly more reliable than the 90C compressors in a FRC environment.
Art Dutra IV
世上无难事,只怕有心人.
  #38   Spotlight this post!
Unread 15-12-2011, 15:27
Brandon Holley's Avatar
Re: 2011 compressor
We didn't have a single issue with the smaller Viair compressor this past season. We had a single 1/2 gallon storage tank with 5 pneumatic cylinders (all but one of them relatively small bore).
We strapped a fan to that compressor right off the bat and it seemed to do a decent job of cooling. It did get warm, but it never got to the point of failing through all of our preseason testing, 2 regionals and 4 off-season events, plus plenty of summer demonstrations.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #39   Spotlight this post!
Unread 22-02-2013, 17:54
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Re: 2011 compressor
We measured both compressors filling 4 air tanks a) from empty and b) from 100 psi to 120 (more realistic in a match: compressor comes on at ~100 psi.
In both cases the Thomas was noticably faster. The 100->120 test was 28 secs versus 39 seconds. You might ask how that is possible when the Viair is rated at 0.34 cf/m at 100 psi versus the Thomas at 0.24 cf/m at 100 psi (at 13.2v). You would hope the difference would be there (scaled down) at 12v operating voltage. Clearly the Viair either falls apart at 12v or they have a different way of rating their compressors.
Of course the Viair is way lighter, way smaller profile for limited space robots but does run hotter (but just as you don't touch motors immediately after a match, don't touch the compressor). I have not heard of any reliability complaints.
  #40   Spotlight this post!
Unread 22-02-2013, 17:58
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Re: 2011 compressor
Originally Posted by Bruceb View Post
Is there no official FIRST place to purchase one of these??
Bruce
http://www.andymark.com/product-p/am-2005.htm
They have the new compressor.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
  #41   Spotlight this post!
Unread 22-02-2013, 18:01
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: 2011 compressor
Originally Posted by thefro526 View Post
The 2011 compressor seems to run extremely hot from my limited experience with it, and by hot, I mean hot enough to burn your hand if you're not careful.
For quite a while last season I had an imprint of the heatsink of that compressor burned into the palm of my hand...
For those of you wondering, they do cook ridiculously quickly. We went through 2 in 2012
2015 GKC Engineering Inspiration
2015 Colorado Winners
